Question about Trendware TEW-432BRP Wireless Router (TEW432BRP)
Does the internet modem and the trendnet router have to be in the same building
    Champion:
  • 329 Answers
No, unless the distance is to great in which case the signals attenuate.
Posted on Aug 21, 2014
SOURCE: trendnet router
i found out that since i have an older version of winxp 2000, i need to get a network adapter, to get this router going.
Posted on Mar 25, 2008
myrlex
  • 674 Answers
SOURCE: wireless connection excellent / won't connect to internet
TRY TO CHECK YOUR CONFIGURATION... OR RE CONFIGURE AGAIN WITH THE CARDS.. MAKE IT SURE THE SETTING IS CORRECT. USERNAME AND PASSWORD YOU ENTERED.
Posted on May 26, 2009
SOURCE: Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
Posted on Jun 18, 2009
SOURCE: Trendnet TEW-432BRP wireless router doesn't connect to internet
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. Dont use the setup cd, sometimes it works, sometimes its not. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Posted on Aug 17, 2009
SOURCE: how can I set up a speed stream 4100 modem/router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the trendnet router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the trendnet router and the other end to the lan port of your computer..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe. Im sure if the computer is connected to the speed stream 4100 modem router you can have an internet access. just in case u did a pppoe settings on the trendnet router and ur done setting the router, u did the connection, then u dont have an internet, set the speedstream modem router to bridge mode
1. click on start
2. run
3. type cmd
Posted on Aug 30, 2009
My TrendNet modem has the "System" light always
Hello
Your going to need to log into the modem/router.Check with manufacturer on how to log in.
Once logged in there should be a page, to turn wireless on.
Here is a link to your router user manual.
http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1504
Oct 19, 2011 | Trendnet Wireless Home Router TEW651BR
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
Apr 28, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
Trendnet set up on my computer
-> Connect your Modem or Internet to the WAN port
-> Connect your computer to anyone of the LAN port
-> Check if you have internet
If not, You should be knowing what kind of Internet you have DSL/Cable
Check if YOu have a WAN IP. WAN IP should not be 0.0.0.0
http://192.168.0.1->Advanced setup-> System ->Status
xtjdeeblsvxsw4felwm6vryrdkruutd3bv9ylzur8ud+atfl9kwj992js4mrf2e4nktvap1qwkdy2svrtzxjy3g5vedqnwhg8bl3khhwclf9hbkld8fc7fjsw21zebaj4nff+s6a6bxuis4qsmahyc4suq69ujyv+8p8hc8qa+qfhffnqg2apvq72tgrqp4bmu7yiohsankn5fudyat1c8i6b4aj+gebdb8qa+qfeuguibfpjf8qaaud6o4sufb6p4ajdi8f8ddsvnsj0mvlmaaaaasuvork5cyii=
If it is 0.0.0.0
-> For DSL you have to configure it in PPPoE
-> For Cable you have to configure it in Dynamic IP and click MAC clone
Feb 28, 2010 | Trendware TRENDnet TW100 S4W1CA...
I got not internet access
O_O Can you connect via ethernet without the router? Try turning off ALL security in the router. Is this your router: http://salestores.com/trendw64.html
Here is your manual: www.trendnet.com/download_manager/default.asp?iFile=2817
Other than that, you havent provided enuf info.
Dec 03, 2009 | Trendware TRENDnet TEW-435BRM 802.11g...
Slow internet connection
Sometimes ISPs (Internet Service Providers) upgrade information on their end to improve or alter something about their network. When this happens, routers have outdated information from the modem. You might want to try power cycling the modem and router. To do this, unplug the power from both the router and modem. After about 15-30 seconds, plug the modem back in. Wait for all of the lights to come on excluding the "PC Activity" light if it exists. Once the modem is registered with your ISP, plug your router back in and test your net speed using a site such as:
http://www.speedtest.net
If your service is back to normal, then you're all set. If it isn't, you may want to contact your ISP as there could be something wrong with the route traffic is taking from the node to your residence.
Mar 05, 2009 | Trendware TRENDnet TEW-452BRP 108Mbps...
Trendnet router
I know you've heard this many times by now, but disconnecting the power from the router for about 30 seconds then reconnecting power should work. Obviously not. If your Xbox and laptop are doing the same, then it's not a computer problem; we can narrow it down to the router, the modem, or the internet connection itself (whether it be DSL or Cable). You may end up having to throw money at the problem and purchasing a new router. I'd recommend an 802.11n router from Linksys. If you're not willing to shell out money, even if you are, you should really try the Trendnet web site or giving them a call. You may just need to update the firmware. Try starting with Trendnet since the problem can be narrowed down to your router. Please let me know what happens.
Dec 27, 2008 | Belkin (F5D9230-4) Wireless Router...
Can't connect to internet
just try to power down your router for a minute or two then fire it back up again...9times out of 10 this resolves the issue...failing that try re-installing the wireless adapter.... hope this helps
Dec 11, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
May 13, 2008 | Trendware TEW-432BRP Wireless Router...
Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
43 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
