Question about Home
Mainstays digital scale
When is turned on, message OUR 2 comes on. What does that mean
2 Suggested Answers
SOURCE: What does the Bone Mass number mean on my digital scale?
I found this from another posting. Hope it helps.
FEMALES: age 20-29 normal= 6.2-7%
FEMALES: age 30-39 normal= 6-6.8%
FEMALES: age 40-49 normal= 5.6-6.4%
FEMALES: age 50-59 normal= 5.2-6%
FEMALES: age 60-69 normal= 4.9-5.7%
sorry no listings over age 69
My only thing now, is what it means if I am below the range.
Posted on Jan 13, 2010
What does oue2 mean on the scale
Best Answer: Most digital scales have this message (OUTZ) and it can mean that your scale has been overloaded or has simply lost its calibration. If the scale was overloaded, then it is probably done for. Sometimes you can try recalibrating the scale using the manual to fix it. If the scale was delivered with this message, then I would call the manufacturer to have it replaced because it is considered DOA. If it has been some time since you purchased the scale though, and it was damaged from overloading, you may be out of luck, as overloading wouldn't be covered by warranty.
Scroll down a few sections on this page to section 4.
http://www.awscales.com/support/faqs
Oct 10, 2016 | Health & Beauty
Err message on Scale. Tried changing the batteries, but no luck!
Enable to capture zero +/- 2%
One or more of the sensors need replacing
Dec 20, 2013 | Seca 354 Digital Baby Scale Pediatric...
My Taylor Lithium scale reads a message "BAEE" What does this mean? I no longer have the booklet. Thanks.
my scale does the same thing. battery reads 2.85 volts. could that be a low reading for a lithium battery with a 5 yr guarantee? hmm.
Dec 13, 2010 | Taylor & Digital Scale Lithium Scale
WHEN YOU GO TO STEP ON THE SCALE IT SAYS ERR1. WHAT DOES THAT MEAN?
When you step on it and get the err1 message step off wait a few seconds and step back on, remember that while the scale is processing your weight you MUST remain STILL.
Good luck
Aug 12, 2010 | Taylor & Digital Scale Lithium Scale
Display gives Error message
On my scales you have to have bare feet for it to measure body fat index, if you still get err, moisten ythe soles of your feet with a cloth to get a better contact.
Jan 28, 2010 | Tanita Digital Body Fat Scale with 2...
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Err message
The "Err" problem is a very common one but no one so far could predict the reason causing this.It means that there has been an
error in the scale measurement.The only solution mentioned everywhere is to Step off the scale until its LCD screen blanks and Step back on the scale.
Jan 20, 2009 | Homedics Glass Digital Scale - Advanced...
Home Logo
77 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
