Question about Dryers
Clothes getting caught in Kenmore dryer
I had a repair man look at my dryer who said the drum needed to be replaced. I thought it would only be the plastic ring that was attached to the drum that came off. He said that the gap would be too big even if that was replaced and I don't think that it would be cost efficient to do that given the cost of labour and drum I would look at buying a new dryer. Can you let me know if there is anything else that should have been looked at? I had some problems with this dryer in the first year with clothes that had strings attached getting caught which was fixed with putting felt in between the drum. The dryer now is only 5 years old.
    Master:
  • 796 Answers
The bearings under the drum may have failed, making the drum drop, so the gap is bigger. Replacing drum or bearings is a lot of work, cheaper to replace the dryer. Or you could make a plastic ring yourself that is thicker to fill the gap....
Posted on Dec 28, 2013
  • 126 Answers
SOURCE: NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Posted on Jan 07, 2009
  • 744 Answers
SOURCE: clothes keep catching in front ring area
>>A repair man replaced the plastic ring but the gap is still there, ruining several items per load. Is it repairable or a fatal defect?<<
The repairman should check the drum rollers, the guides, and the baffles to be sure the dryer drum is rolling true (round). Also, the replaced ring should be re-checked to be sure it's installed correctly.
Posted on Apr 11, 2009
  • 16 Answers
SOURCE: For past few years getting brown streaks on all my
that is one of my absolute least favorite repair jobs. its messy and a little hard to do. save for pro
Posted on Jun 27, 2009
  • 84 Answers
SOURCE: Frigidaire dryer drum liner
yeah, i think there called "drum glides" www.partselect.com type in your model number and you if they have that dryer in the system, then breakdown of the dryer will show, multiple diagrams. And look for the glides that are supposed to go there...hopefully this helps
Posted on Jul 31, 2009
  • 126 Answers
SOURCE: Our Kenmore 70 series dryer is leaving a brown stain on clothes
replace drum rollers and rear seal (felt,cloth)
Posted on Oct 10, 2009
Testimonial: "Thanks"
My dryer made a loud bang and wont spin
Bridgette, Most common problem is a broken belt when dryer drum dose not turn. Look through the attached links to help diagnose and repair your dryer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Drum Not Turning
Whirlpool Dryer Drum Not Turning
Appliance Repair Forums
Duet Dryer Drum Belt part 661570 How To Replace
Jul 17, 2016 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Clothes getting caught in drum of Kenmore dryer
The repairman is trying to upsell you to a replacement drum. The felt sealer can be an expensive item to replace. Go to www.repairclinic.com and enter the model of your dryer. With luck, you will be presented with a list of common replacement parts that will give you some idea of cost.
Apr 28, 2017 | Dryers
Hi I have a Beko / flavel TD162 W dryer . The belt broke so I replaced it yesterday , however when i opened it the drum was actually seized so I thought the back bearing but no it was fine . The front of...
I believe you will need to replace the drum glides since the drum rollers are good:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 16, 2011 | Dryers
Duet dryer drum rubbing
There is a felt seal on the drum that might be wore and will need to be replaced.(Note if not replaced it will ware your drum and ruin it.
It is something you will probably want a repair man to check out for you.
Oct 21, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore electric dryer series 70, on the inside of my dryer there is a plastic white ring that is cracked and brittle, clothes get stuck on this ring and tear, can I replace this white ring?
Yes, you can replace that ring.
I believe you have a front loading machine, if so then you will need to remove the front of the machine to expose the ring, drum and belt.
Try this website and see if they can supply the part you need.
Good luck, I hope this helped
http://www.partsselect.com/
Oct 03, 2009 | Kenmore 73952 Gas Dryer
Clothes keep catching in front ring area
Apr 10, 2009 | Frigidaire Dryers
How to repair instructions
The rollers behind the drum need heat resistant grease. You'll need snap ring pliers to remove them. Clean and inspect everything inside, vacuum all lint. Have a spare belt, they're cheap. Check the tensioner pulley for lube, but don't get any where the belt touches.
Mar 29, 2009 | Maytag PYE2300AY Electric Dryer
Dryer problem
You need to replace the rear drum bearing, and also the plastic bearing pads at the front of the dryer, where the drum goes round against the front panel.
There is a repair kit that contains all the parts you need to carry out this repair, with instructions on what to do.
P
It does involve stripping the dryer down to complete these repairs.
Jan 23, 2009 | Zanussi TC7102W Electric Dryer
Same Problem
iwas not the first tech,,,but to answer your question ..you can use any glue thats quick drying,,,you would come out cheaper going to the dollar store...the drum it self will keep it in place...onthejob
Jul 04, 2008 | Frigidaire FEQ332E Electric Dryer
My clothes are catching between the drum and casing(?), the drum seems to be loose. My dryer is a GE profile/prodigy
suspect front tub support/bearing ring worn remove top by removing screws under front edge of top lift top 1 screw each side of front on inside front ring attaches to front panel look for worn plastic ring and pads
May 31, 2008 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
