Question about THE SHARPER IMAGE ESI-P400 Freedom Premium Wireless Speaker
LOOKING FOR A RESET PAIRING CODE SHARPER IMAGE FREEDOM
HOW DO I RESET PAIRING CODE
Looking for Sharper Image clock/radio soother SI564 manual.
Try Googling (sharper image)(SI564)(manual) without parens.
Dec 10, 2017 | Sharper Image Audio Players & Recorders
I've successfully paired the peaker but no sound is coming out
might I ask how do you know you were successfull if no sound is forth coming .
Mar 31, 2015 | THE SHARPER IMAGE ESI-P400 Freedom Premium...
I got a Sharper Image Bluetooth speaker system and it didn't come with a manual, I can't figure out how to set anything, (radio stations, bluetooth pairing, clock etc) it asks for a code when pairing
easy put your phone or device on and the other device look for it in the scanning option and pair its normaly asks for a pin that is the pin they give you with the phone for the bluetooth option 00000 is standard
Dec 28, 2013 | Sharper Image Portable Speaker System Dock...
Sharper image freedom Bluetooth model number ESI-P400 how to put in pairing mode.
To pair your device with The Sharper Image Freedom:
  1. Make sure your device has Bluetooth capability.
  2. Slide the POWER switch to turn on the Freedom, indicator will begin to flash.
  3. Follow the instructions of your device to pair the unit.
  4. Pair your device with the unit by selecting FREEDOM from your Bluetooth listings on your device or selecting YES. If prompted, enter "0000" as the passcode.
  5. Press play on your device and use controls on the unit to adjust desired volume.
Note: Once you have successfully paired your device, you typically will not need to repeat the above steps. Please ensure the Line-In cable is unplugged, the unit source is set to Bluetooth and your device has Bluetooth enabled.
Note: The effective Bluetooth range of the Freedom is approximately 30 feet.
Nov 19, 2013 | Radio Communications
Sharper image freedom Bluetooth speaker model ESI-P400 discovery mode button sequence
Sharper image jumbo remote to work with dish network
I can help you with your Sharper Image Jumbo remote control.
There are two Sharper Image Jumbo Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals. The included code lists will give you the correct codes you require.
The Jumbo Touch also has a learn function, while the standard jumbo does not.
I hope that helps.
Apr 04, 2010 | One For All URC-9910 LCD Remote Control
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
I Am trying to program the sharper image jumbo sized universal tv remote.I can;t get the Samsung dvd/vcr combo to except any code listed in the instruction manual
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual.
The Jumbo Touch remote does have a learn function which may be helpful in controlling your Samsung DVD/VCR combo.
I hope that helps.
Sep 12, 2008 | Sharper Image Professional Plus Ionic...
I have a sharper image Ionic Breeze GP still under warranty. One of the blue lights on the Germicidal lamp is out and needs to be replaced. Where can I purchase this part, now that Sharper Image is no...
If the warranty you are counting on is a Sharper Image Warranty I need to advise you that it was voided in the buyout on 30 May, 2008 when everything at Sharper Image was liquidated by Hilco Consumer Capital, Gordon Brothers, and Bluestar Alliance. If however it was a warranty company outside of Sharper Image you need to contact them.
You can purchase a bulb for the GP on ebay for under $11, which is really a good price considering what you would have paid from Sharper Image. Installation is easy, you just pull up on the tab on the bottom of the filter and pull up. When you are looking at the bulb, turn it 1/4 turn, (2 clicks) and pull it out. That is all there is to it. Hope this helps you.
Aug 23, 2008 | Sharper Image Professional Plus Ionic...
THE SHARPER IMAGE ESI-P400 Freedom Premium Wireless Speaker Logo
Top THE SHARPER IMAGE Radio Communications Experts
eradiostore
eradiostore
Are you a THE SHARPER IMAGE Radio Communication Expert? Answer questions, earn points and help others
