Question about Water Heaters
A84 Is appearing what does thismean - Water Heaters
Grasslin qe7 water heater wont turn on
Read product manual and it shows no troubleshoot resources:
Turn circuit breaker fully off and fully back on.
http://waterheatertimer.org/pdf/QE7-INSTRUCTION.pdf
http://waterheatertimer.org/How-to-set-timers.html
Gene
h
Jan 21, 2014 | Water Heaters
Ptg 74pvn 2 rtg 74pvp
copy following links for rheem/eco-sense error codes, manuals, required yearly maintenance, support number and resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Probably bad PC board, or bad remote control
Gene
h
Nov 22, 2013 | Rheem EcoSense by 4.2 GPM Tankless Water...
Jacuzzi tankless water heater code 12 appears
For my Jacuzzi tankless water heater model #J-SN180F: It turned out to be an exhaust issue. If I take off the exhaust vent completely then the talks heater works with 3 baths at full hot water. I get the error code 12 again as soon as I put event an elbow of the vent. So my conclusion is I need some sort of straight vent.
Apr 22, 2013 | Water Heaters
Locked out of thermostate
From the manual:
PROGRAMMABLE KEYPAD LOCK
To prevent tampering with any of your settings or
temperatures, the front panel buttons and the rotary dial can
be locked out, requiring a four digit code to unlock them.
You may use either the default lock code of "0000", or your
own personal number combination (see "Changing The Lock
Code")
LOCKING THE THERMOSTAT: Ensure the rotary dial is in the
RUN position. Press the NEXT button for at least 2 seconds.
The words "ENTER CODE" will appear on the screen, along
with "0000". Press the NEXT button again for at least 2
seconds. A padlock should appear on the screen to confirm
that the thermostat is now locked.
UNLOCKING THE THERMOSTAT: Ensure the rotary dial is in
the RUN position. A single press of any button should cause
the words "ENTER CODE" to appear on the screen, along
with "0000". If the default code was used to lock the
thermostat, press the NEXT button for at least 2 seconds.
The padlock should disappear from the screen, and the
thermostat should now be unlocked.
If you try to unlock the thermostat by entering a code that is
not correct, a padlock and the digits "88:88" will flash on the
screen and you will have to try again. If a lock code
different from the default was used, this will need to be
entered by using the UP/DOWN buttons, and the NEXT
button to advance to the next digit. Once the correct code is
entered, press the NEXT button for at least 2 seconds and
the thermostat should now be unlocked.
CHANGING THE LOCK CODE: To create your own specific
lock code, first ensure that the rotary dial is in the RUN
position. Press the NEXT button for at least 2 seconds. The
words "ENTER CODE" will appear on the screen, along with
"0000". Now press the HOLD button again for at least 2
seconds. The words "SET CODE" will appear on the screen,
along with "0000".
IF YOU FORGOT YOUR LOCK CODE: You can still unlock the
thermostat by performing the following steps: On the back
of thermostat locate JP1, which is a row of 3 metal pins at
the right edge of the circuit board above the battery tray.
There should be a plastic jumper cap on 2 of the 3 pins
(right or left).
Move the jumper cap so that it is on the opposite 2 pins.
For this change to be recognized, move the Temperature
Mode switch to any other position than its current one.
These steps listed should have changed the lock code back
to the default of "0000". Follow the instructions already
listed in "UNLOCKING THE THERMOSTAT".
Sep 02, 2012 | Lux Tx9100e 7 Day Universal Programmable...
Boiler leak
Hi, it appears you have a defected relief valve. you can try one solution. lift the handle on the relief valve and let some water out. sometimes that can flush out materials thats blocking the stem in the valve. if it's still leaking it must be replace.
If this doesn’t work for you please write back. Thanks,
Nov 23, 2008 | Watts 3/4 Pressure Relief Valve
Water Heaters Logo
18 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
