Question about Kenmore Ovens
Kenmore mod 970-506021 stove. i replaced the bake element and it goes to temp set keeps heating until F10 code comes on and i have to turn off
jbjaxiis
  • 95 Answers
SOURCE: bottom /bake element will not come on
Check the connections to the element. If power is going to the element, and it is not working, the element needs to be replaced
Posted on Jul 21, 2008
SOURCE: my ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Posted on Sep 08, 2008
  • 3230 Answers
SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
good luck,
Posted on Jun 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: kenmore stove model# 665.92024100 While cooking
Check and see if the broil element has shorted to ground.
Bonus
Posted on Apr 13, 2010
SOURCE: kenmore model 790.9621 electric stove error code
it is the bake relay sticking--on the eletronic oven control board.i tried to buy the relays but,no luck.must buy the eoc board-great engineering
Posted on Aug 09, 2010
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
What does code f10 mean?
get a small oven thermometer and put it inside the over to check what temp it goes off at .many times it is a bad thermocouple .
Sep 25, 2015 | Kenmore Ovens
How do get rid of F10 which is on the window of my Kenmore stove
The F10 error means that the high temperature sensor is reporting a runaway temperature and shut down to avoid a potential fire. Try unplugging the stove or tripping the circuit breaker to reset the code.
If the error recurs, unplug the stove (or turn off the circuit breaker) again. Look at the broiler and bake elements with a flashlight. If it has any damage (breaks, char, melting), you will need to replace the element. Check where the elements connect to the oven and replace them if there is any charring on the back wall.
If the elements are undamaged, you need to check the wiring to identify if the problem is at the elements, the high temperature sensor, wiring or the control board. You will need to access the wiring from the back of the stove. Disconnect the wires to the heating elements. Then disconnect the wiring connections at the high temperature sensor and the control board. Without a model number, I can't be completely sure of the resistance that should be seen at various points. Please post a comment with the model number of the stove and I'll try to confirm the expected and faulty resistance values. Most likely, the resistance should be under 50 ohms but above zero between the left and right contacts of the elements and the violet wires in the wiring harness at the control board. The high temperature sensor should probably have a resistance between 1,000 and 1,200 ohms. If the resistance is high, you'll need to replace the appropriate parts. (Note: if the wiring at the control board gives a reading similar to the resistance of the high temperature sensor, the control board is the likely suspect.)
I hope this helps. If your stove is under warranty, contact Sears/Kenmore to fix the issue. If you aren't comfortable testing the wiring, contact Kenmore for a service call.
Feb 04, 2015 | Kenmore Ovens
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore stove model# 665.92024100 While cooking
Bonus
Apr 13, 2010 | Kenmore Ovens
Kenmore model 790.9621 electric stove error code F10. The oven heats up on bake (set at 400 degrees) then goes into f10 mode; and seems to be heating up more. Answer for problem??
Jan 02, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
GE True Temp oven won't turn off.
The sensor is a part number WB23T10002 and goes for about $60. The paper inside the control area of the oven will state the normal resistance values of it. (probably about 1080 ohms at room temp, about 2650 at clean temp.) If you cut a lead to it, you would just get a F3 code, and if you cut the other and wire them together, just get a F4 code, so that wouldn't help diagnose the problem, but if you could use an ohm meter on the probe it would. BUT the oven should not come on without it being set to bake, SO I conclude that the ERC is indeed the problem (with the welded electrical contacts), which is a part number WB50T10043 which might go for about $125 or so. If you are careful when you replace it, you can probably peal the faceplate (part # WB27T10125) off and reuse it, so you should just need the ERC.
May 05, 2009 | GE Ovens
My ge spectra stove bake element is not heating
Dec 18, 2007 | GE JKP20 Electric Single Oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
140 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
