Question about Measuring Tools & Sensors
Fluke 12 multimeter
Hi! The Range switch on my Fluke 12DMM no longer works in any of the ranges - Volts AC/DC, Ohm etc. I have opened it and the actual push switch is fine. I have cleaned the little multi-connector cable as well as the contacts both sides. Still no go. Any ideas would be welcome. Regards, Eric
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Did you change the micro fuse , do that first
Posted on Dec 27, 2013
Testimonial: "Sorry, I should have been a lot more specific. It works on DC Volts when I switch the meter on, and also on the diode test when I move the selector to the Ohms etc range. But I cannot select Capacitance or Ohms when depressing the "Select" switch from the Diode test, or AC volts when on the DC voltage selection. The Select switch does function when I test it for operation using another meter. In any case, I found two small fusees under the PCB, both are fine. Regards, Eric"
3 Suggested Answers
  • 172 Answers
SOURCE: My fluke 337 clamp is reading 370A on DC function
This meter has been recalled due to a circuitboard problem which may lead to severe shock. Please go to flukes website at www.fluke.com/33xrecall to download the forms and get information to see if yours is one involved in the recall.
Posted on Jan 06, 2010
SOURCE: Fluke 8060AA digital multimeter
test unit reads okay then goes into - OL mode unable to take any readings
Posted on Jul 12, 2011
Fluke 179 not working on voltage
possible blown fusible resistor (check for open or very high resistance - should be about 1kOhm) - first big resistor in Voltgae terminal circuit
Mar 16, 2013 | Fluke Networks Fluke 179 Electricians...
Fluke 179 multimeter showing wrong reading in AC, DC voltage, rest every thing working ok
input protection circuit is blown , see if you can find fusible resistor and check for open circuit (should be 1kOhm) - big resistor on the right straight from the Volts input
Mar 15, 2013 | Fluke Networks Fluke 179 Electricians...
Multimeters
Short Answer = YES.
Fluke 16 has a 4000mV range that can be entered only manualy. If you use auto range it will go to 4V as the lovest range but if you keep pressing range button you can go to 4000mV range with 1mV resolution.
Nov 14, 2012 | Fluke Networks Measuring Tools & Sensors
I want to no test something for 3 volts testing a solar cell
Using a good quality digital multimeter (voltmeter) set to DC VOLTS should be an adequate measuring device for that purpose.
Here are some links to a few reliable multimeters currently available for sale on EBay for a range of prices depending on your budget:
http://www.ebay.com/itm/New-VC97-3999-Auto-range-multimeter-vs-FLUKE-15B-tester-/280682146497?pt=LH_DefaultDomain_0&hash=item4159f5aac1
http://www.ebay.com/itm/FLUKE-17B-F17B-Digital-Multimeter-Meter-NEW-/320802914117?pt=LH_DefaultDomain_0&hash=item4ab157ff45
Just use your mouse to click on the links, which are the underlined and blue highlighted sections of text just above.
This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 16, 2011 | Cars & Trucks
Fluke 179 has ---- on the display when ohms or amps selected, but is ok on volts ranges. any ideas?
Switch is the problem here, see if you can clean contacts or check if switch contacts are broken.
Nov 30, 2010 | Fluke Networks Fluke 179 Electricians...
My Fluke 179 has stopped beeping (mode switch/continuity/range alert) Any way to fix this?
Needs new buzzer disc, or maybe buzzer disc fell out of its place and just repositioning it fixes the problem.
Nov 07, 2010 | Fluke Networks Fluke 179 Electricians...
Reads random voltage in AC mode
I use a fluke everyday. If it has been dropped, it will need to be recalibrated by fluke. Mine has a range button, try to use a lesser or greater range depending on what range it fluctuates
Dec 20, 2009 | Fluke Networks Fluke 83-V Digital...
When an electronics panel has power fualt which machine
USE A MULTIMETER TO CHECK YOUR VOLTAGE, MAKE SURE TO CHECK ON DC RANGE, AND THE OUTPUT SHOULD BE IN BETWEEN 7-12 VOLTS DC-----WWW.FLUKE.COM
Oct 16, 2009 | Prosonic PDS-758-LP Portable DVD Player...
Measuring Tools & Sensors Logo
77 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
