SOURCE: Phone Sending MMS Messages as Default
The phone allocates a certain amount of storage for messages on a whole. Even though there may still show space available for text messages, you have hit an invisible "limit" and the phone is now defaulting to MMS messages because there is "room" there. Delete a fair amount of messages and you should be able to start sending regular text's again.
SOURCE: motorola razr v3xx - automatically sending text messages in the multimedia/picture format
Hmmmm, a good one. I need to ask first, who is your service provider? I can walk you thru it after i know who your with.
SOURCE: MMS messaging?
This may be the problem...
Go to messages,
press menu ( - )
go to message setup,
then MMS message setup,
then go on composing MMS,
change the reply type to short reply
Hope this helps
Mowcius
SOURCE: Unsupported message type
hi. it might be some virus kind of thing tarnsfered to ur mobile from other. it may even comes as text messages. rate me
SOURCE: my phone keeps shutting off every time i go to type a text message
If it's truly a loose battery, more than likely it's the connections that are making secure contact. You can try with a thin pinted implement to pry the connection tabs on the battery compartment (the connectors onthe battery itself are fixed and imovable) outward ever so slightly and that will make for a better connection. But use care so that you don't over bend and break the connections.
Also look for any corrosion onthe connections which can cause intermittent failures.
