Question about Refrigerators
Maytag RTD1900 not cooling
I have a Maytag RTD1900 that has the freezer located on the top. Starting in March it was running a lot more than normal. By the end of August I could not get the fridge to cool much at all but the freezer was still working at 10 degrees. Things were frozen but ice cream was soft. I can also tell there is a vast difference in the coldness of the air coming into the freezer I could finally afford repair in October. They said it was the fridge cold control and replaced it, but it was still running a lot. The manager said the problem was the freezer was set too high. In this model, the freezer cools the fridge and there is a damper between the two. Apparently because the freezer was set so high, the damper was mostly closed and there was very little air getting into the fridge. I called again a few weeks ago because it still was not that cold and ran a lot. They finally took it apart and said that only half of my evaporator coils had frost. They felt this meant it was low on R12 Freon. If it was leaking Freon but not getting substantially worse from March to December, would not have all of the Freon already leaked out in 9 months? I feel the air flow is not what it used to be in the freezer. The evaporator coils were not iced up, the outside fan and coils are clean, the compressor gets warm but not hot, the cooling copper line from the compressor is sort of cold, defrost timer does come on occasionally and there is some water in the drip pan. Any ideas? Does this sound like a Freon issue? This company wanted to recharge it but I do not want to pay for that if it is not the problem.
  • 128 Answers
Where you said there was a damper is it not a fan .usually against the back wall in the freezer there is a fan that forces the cold air from the freezer to the bottom compartment.See if there is one and check to see if it is turning that may be your problem
Posted on Dec 27, 2013
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
aborcass
  • 2651 Answers
SOURCE: Amana DBR 2201 CW fridge, freezer good fridge not cooling
sounds like you have a bad evaporator fan motor, located in the freezer section ,it circulates the air up to the refrigerator compartment
Posted on Nov 30, 2008
  • 56 Answers
SOURCE: Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Posted on Mar 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Freezer not cooling/making ice.
At this moment I think that you need to unplug the refrigerator and remove the ice maker to stop the leaking. Any extra water inside the freezer will make it harder for the defrost to remove the moisture. While the ice maker is out I want you to look to see if water is still leaking out the fill tube that feeds the ice maker tray. If it is then we found the reason. If not then we need to check some of the parts on the ice maker. Let me know what you find, Thanks, Sea Breeze
Posted on May 20, 2009
heatman101
  • 43501 Answers
SOURCE: The Refrigerator is 2 years old, and is no longer
Hi Chris,
The problem would seem to be that you developed a small leak in the refrigeration system. This is also assuming that you checked and cleaned the condenser coils which are underneath the fridge. Excessive dirt could also cause this, but from what you are describing I would say the problem is more then that and you have a leak...
The only other thing would be thermostat sensor issues, but then the compressor would be cycling and not running steady...
heatman101
Posted on May 18, 2011
Refrigerator not cooling
replace the ptc overload/relay on the side of the compressor this aids in starting and running of the compressor
Jan 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MTF1895AEW Not Cooling
Sounds to me the compressor start relay=> 63001003 Overload=> 63001004 and Run Capacitor=> 63001005
needs replaced, the clicking noise indicates that that is the problem, Sea Breeze
Feb 16, 2012 | Maytag Refrigerators
Maytag RTD1900 freezer working fine, refrigerator not cooling water dripping from top.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Refrigerators
Refrigerator does not cool. Coil in back of freezer has lots of ice and frost on it. SIde by SIde Maytag Model mzd2766ges. I bought a defrost control board hoping to solve the problem but I can't find...
. Look inside the freezer compartment for your circulation fan . This fan should run when the unit is in a normal operation mode. You should be able to hear it running making a whirring sound when you open the freezer door . If you do not hear it running , replace it . If the fan it's OK then your problem is going to be in the defrost control circuit or associated components .
Feb 22, 2011 | Refrigerators
The freezer is fine, but the refrigerator seems to be working below normal. What could be the problem?
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 26, 2010 | Maytag PTB1953G Top Freezer Refrigerator
Freezer isn't working and refrigerator isn/t cooling. What is the problem? We can hear the fan running however.
my refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
Nov 15, 2009 | Maytag MSD2756GES Side by Side...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
FREEZER NOT WORKING
that is very possible if the fan and compressor are running. the best thing you can do is call maytag. its only 4 months old and is there problem to fix. Good Luck
Aug 03, 2007 | Maytag Freezer MQU2057
Refrigerators Logo
177 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
