Question about Philips 51PP9303H Rear Projection Television
Colors coming apart at bottom - Philips 51PP9303H Rear Projection Television
  • 1,511 Answers
You need super glue.
Posted on May 09, 2014
Need a color wheel for a hcm5525w samsung
This model of Samsung is a CRT based projection TV that usues no color wheel : (
Jul 25, 2011 | Samsung HCM5525W 55" Rear Projection...
I changed the laser cartridges and the red seems to come out orange. The colors aren't just right. I have preformed 3 color calibrations. Is there any thing else? I have Vista. HP 2605dn laser printer
Your laser/scanner assy needs cleaning. The main fan, located at the bottom is getting dust from below the printer and blows it to the lower (magenta) mirrors of the laser/scanner assy.
To repair, take the printer apart. Remove side and back covers. Then remove the metal frame with the boards. The laser/scanner is a black box behind the frame. Take it out and open it. Clean the mirrors.
To make the repair permanent, cover the fan's vents with sticky tape. I usually remove the plastic gratings to seal better. It will cause no problems to the printer.
Aug 17, 2010 | HP Color LaserJet 2600n Printer
I cant remove the battery fron its
On most there is a hold that bolts to the bottom of the battery tray with a 12mm bolt. This hold is hard to tell apart from the battery itself - same material, same color.look down on the bottom for a triangle shaped tab that has a bolt in the center, loosen this bolt and she should come out.
Dec 29, 2009 | Cadillac SRX Cars & Trucks
Small bars across picture with no color
I have exactly the same problem and a Dell tech just recommended I replace the drum cartridge - $170.
Nov 07, 2009 | Dell 3000cn Laser Printer
Sony KDF-42WE655 Television has change of color at bottom of screen. Bright almost neon blue replacing the regular color scheme when watching TV. Slowly becoming worse as in the blue area seems to be...
Your optics engine has failed in the set. One of the LCD's usually the blue has come apart and is smearing. The only way to correct this is to have the optics engine assembly replaced.
Here is website which might be able to help you.. There prices are very reasonable and units are refurbished to factory specs, you might need to have a technician come and install if for you, but you save yourself alot money going this route.. The pic will only get worse with time..
http://www.discount-merchant.com
Thanks please leave a comment if this helps..
Delhielectronics@live.com
Sep 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i take apart my kicker L5 15" comp. sub?
you blew a voice coil or two if its a dvc. all youll see is the copper winding is a blueish in color because its burned and could not carrie the singal ...just take it apart ..cut the top all the way around and same on the bottom on the holder its what stops the sub from coming.to far out. then pull it out..
Sep 20, 2009 | Kicker Solo-Baric L5 Car Subwoofer
How to take the door handle off?
the handle screws into position. one screw at the top and one at the bottom. you may have to take the door all apart to find those screws.
it may be easier for you to tape off the parts you do not want to paint and just paint the handle.
Jun 26, 2009 | LG LMV1630ST Microwave Oven
Vertical dots on print output
1 1/2 inches apart would correspond to the diameter of the primary charge roller. You have one chrarge roller inside each toner cartridge so you need to determine which color the dots are and then replace that cartridge.
Oct 22, 2008 | HP LaserJet 4600dn Color Printer
29273GE2-A
yes this phone requires batteries, i think its double A, but check to make sure
Jun 14, 2008 | GE 29273GE2 Phone
Televison & Video Logo
12 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
