Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Now i hear a click then buzz then click. compressor gets warm but fridge is still freezing and cooling. should i replace the compressor starter because it rattles when shaken?
It might be on the way out I would get the new relay and have it ready when the box fails. leave it be till it goes on out. But be ready. If it was bad it would either not do nothing or overheat and shut off.
Posted on Dec 27, 2013
Testimonial: "hi dan webster i just posted in response to your post any addittional info would be a gr8 help!"
SOURCE: Refrigerator buzzes & clicks
The only thing a capacitor does is 'kick' the compressor to start it. There is a box on the compressor containing the start relay. If it is defective or dirty, it might buzz. With the power off, find it, remove its cover and use some canned air to blow off any dirt inside. If that doesn't fix it, replace it. If there is a fan down there, be careful...and be sure it is working.
Posted on Dec 23, 2007
SOURCE: Rattling compressor on Kenmoore bottom freezer refrigerator
IF IS NOT 5 YEARS OLD YET CALL A TECH ASAP THIS MODELS HAVE A COMPRESSOR THAT ARE FAMOUS FOR LOCKING UP AND THE ONLY FIX IS TO REPLACE IT BUT FIRST DISCONNECT AND REMOVE BACK COVER AND RIGHT BY THE COMPRESSOR THERE IS A SMALL BOX ATTACHED TO IT CALL A OVERLOAD REMOVE IT AND SHAKE IT IS IF RATTLES THEN JUST REPLACE THAT PART IF IT DOESNT RATTLE CALL A TECH
Posted on Nov 10, 2008
SOURCE: My Kenmore side by side refrigerator is not freezing nor cooling.
surfgl,
The model you posted does not help me much but a rough estimate would be (from Sears) about $400.00 for the compressor + about $225.00 Serv Call and Labor. Possibly another $15.00 access valve and then tax.
The problem you have is that the compressor is locking up then it may run again for a short time. It will eventually lock up and not run again. If you can prove it is (by receipt) that it is less than 5 years old, Sears will repair it free under the sealed system warranty.
The model # and serial # should be on a sticker in the top front of the ref section. If not then on the left wall or right wall top front of ref section.
If this helped please rate me good. supertechks
Posted on Nov 25, 2008
Sep 08, 2011 | Samsung Refrigerators
Jun 30, 2011 | Refrigerators
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 24, 2011 | Refrigerators
Oct 07, 2010 | Refrigerators
Jul 07, 2010 | Magic Chef CTB1722 Top Freezer...
Nov 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Aug 16, 2009 | Frigidaire PLRS267ZAB Side by Side...
Jun 13, 2009 | Frigidaire FRS23KF7AB Side by Side...
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Mar 30, 2008 | Refrigerators
101 people viewed this question
compressor nis getting hot so i unplug fridge let compressor cool then plug back in. fridge will run quiet for hours then begin with the click buzz click again and i shut it down. starter relay is on its way!
and just more details here dan but it seems the compressor keeps running until it reaches a point were mab the heat of the compressor start the click buzz click routine?
got start relay and the click buzz click is gone. will relay more info as success or failure allows thank b 2 u o danny boy
got home compressor was on fire so unplugged. later the click buzz click returned. what is my next option?
Probably a bad compressor internal windings fried
