Question about Car Audio & Video
Cannot enter radio code for Opel Astra.
I am trying to enter the radio code on my 2000 Opel Astra but when I press and hold the AS key and turn on the radio I don't get the option to enter the code: the display just shows SAFE. The AS key is not doing anything. Am I doing something wrong?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Go to dealer for new code
Posted on Dec 27, 2013
  • 4930 Answers
SOURCE: I have a cdr2005 vauxhall radio which went into
Leave SWITCHED ON ...UNDISTURBED for a couple of hours and that will automatically reset it
Posted on Oct 12, 2009
  • 4930 Answers
SOURCE: opel factory fitted radio codes
Unfortunately the majority of SIEMENS/VDO codes (including your CDR 2005 )  will  NOT  be available for free (or cheap)  from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
To reset from 7SAFE  then LEAVE SWITCHED ON ....UNDISTURBED for as long as it takes to automatically reset itself (usually an hour or two)
Posted on Dec 07, 2009
Testimonial: "Thanx man... Ill take it to my nearest dealership Thank you for the quick response"
steve_e_uk
  • 1675 Answers
SOURCE: got the codes for opel astra put them in wrong 3
unfortunatly there is no recovery from 3 x wrong input, when this has been done there is a chip that locks out, and you cannot recover it, you can however try removing the battery for a while abou half an hour to see if it will reset so you can put the code back in this is not gaurenteed to work as some chips blow deliberatly as a security device incase the radio is stolen it makes it u/s to the person...if you have a serila and make/ modle i might be able to help with a code if you can get it back to the stage where it asks for one..hope this works
Posted on Feb 15, 2010
  • 4930 Answers
SOURCE: I lost the radio code of my opel Astra 1994 can
try asking here
ukbookshelf.co.uk
Posted on May 17, 2010
  • 4930 Answers
SOURCE: astra radio code - i know the code, entered it as
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
(It could take many hours)
Posted on May 30, 2010
How to i reset the password
usaly meens the head is stolen and u would need to take it infor reset
Feb 02, 2008 | Kenwood Excelon KDC-X990 CD/MP3/WMA/AAC...
I have the code how do i enter it
1.turn the ignition on to reds .
2.turn the radio on.
3.on the front panel of the radio you will see a button with the lettering asp hold it in until it beeps.
4.then for example if the 1st number of the radio code is 4 ,you will have to press no1 until the 4 appears ,next number use no.2 and so on.
5.once all the number are entered then hold the asp button again until it beeps .
you are now finished the process
Feb 17, 2015 | Holden Astra Cars & Trucks
How can i fix if faul code er 77 , large circuit resistance triggered patron side airbag on the left side.I have tried to pull out contact on the ECU but no results.
Each manufacturer has different reset procedures if you can't take it to a garage and reset by odii ecu computer routes.forums for your make and model will suggest something similar to leaving the driver door open and then hold the courtesy light switch at the bottom of door before turning on ignition.turn on ignition one click but don't start the car.then release and press the door light switch say 5 or 6 times within ten seconds on the last count hold it in and turn off the ignition.close door then start car.sometimes you need to experiment as the number changes with different models.my car resets on 7 presses and I have to close the drivers door and open passenger door before I start car.
Dec 04, 2014 | 2000 Opel Astra
How do i enter the radio code on an opel vivaro van
Hi just this second fixed mine. Turn on ignition then turn radio off press and hold the AS button and keep it depressed while turning radio on. The display will now show a number for how many attempts you have and 4 dashes. press button number 1 till the first digit of youe code is displayed ,then button number 2 again till the second digit of your code is displayed and repeat with number 3 and number 4. when the correct code is displayed push and hold the AS button and keep depressed while turning radio on (basically a reverse of what you did to access input code screen.you will hear a beep, the screen will recall its memory takes abbout 20 seconds then your good to go... Hope this helps.
Jan 30, 2009 | Car Audio & Video
Radio lock
Try this if it works to your unit;
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 07, 2008 | 2001 Chrysler Sebring
Entering Code for Car Stereo
Turn on the ignition, turn the radio off fully. (by preeing the volume wheel knob) press AS or the button that turns it to CD mode (should have circle on button)keep it pressed and turn radio on. wait for a beep then it should be somthing like:
10----------- (10 being the number of tries left)
use buttons 1,2,3 & 4 to input your code. press the button more than once for it to rise higher.
Hope this helped.
BTW i got the same problem with my dads astra. but i dont even know the code :(
Nov 24, 2007 | Car Audio & Video
Car Audio & Video Logo
135 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
