SOURCE: HP Color Laser Jet 1600 Problem
Hey I have 1 problem I have the printer of 2600n when i give print Command of RED Colour its come orange and right side i get light print and left side i get little dark print , what is the problem i don't understand any can help me . Thank u Morgan.M
SOURCE: red color on hp 1600 not work fine
1. Turn off the printer.
2. Press and hold the (Select) and (Cancel Job) buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init displays, release the (Select) and
(Cancel Job) buttons.
When the NVRAM init is complete, the printer will return to the Ready state.
SOURCE: Our HP Color Laser Jet Printer keeps saying 50.2
I had a similar problem. make sure the fuser is the same voltage as the printer. 110v printer needs a 110v fuser. easy way to tell. White barcode sticker it is a 110v. Red or Pink then it is a 220v.
SOURCE: hp 1600 laser, entire page comes out sligtly black
How old is it?
Page getting dark sounds like the drum getting old.
SOURCE: MY HP
This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer will need to be cleaned by a certified HP technician to resolve this issue as it means dismantling your printer to fix the problem.
