Question about Ariston Technologies Washing Machines
Flashing lights All of the lights on the front of my Hotpoint Aquarius Wf541 washing maching are flashing on and off, leaving me unable to use the appliance. Any help or advice in remedying this problem is appreciated.
  • 6,784 Answers
HI, this is a control fault that may be corrected by unplugging or shutting down the breaker switch for about five minutes. this will reset the microcomputer to its original state. after the five minute reset, plug or switch the machine on and observe the results.
If the unit is still blinking and the unit is not operational, this will confirm a major control fault and you will need to replace the control board(microcomputer/timer control)
Posted on May 18, 2009
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius hotpoint wf541 wont pump the water out at the end of the cycle
You need to clean the filter.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well
Hope this helps with your problem
Dec 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius wf541. Am trying to remove pump filter to clean .
think yourself lucky my plastic broke when i was unscrewing it or tying to ended up cutting my knuckle open on the shard of plastic and water pumping out all over my kitchen is there somewhere that you can purchase the cap from and how do you get the broken one off???
Nov 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I have an Aquarius WF541, only about 18 months old. It keeps washing and washing but does not proceed to rinse and pump out. There are no flashing indicator / warning lights when this is happening. Any...
If the machine is under 5yrs old ring Hotpoint.. They will charge around £90 to repair the machine including parts and those parts will be guaranteed for a further year...
It sounds like you have a control board issue and the control board plus labour would cost you in excess of the Hotpoint charge
Aug 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Machine do not take detergent from the dispenser at all
that sounds to me like a water pressure problem. check the hoses aren't kinked and that water comes out at a reasonable rate.
the small filters where they attach to the machine may be limescaled up and want cleaning.
Feb 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
WF541 Hotpoint
Have the control board checked first
Apr 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
582 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
