Question about Digital2 7 inch Tablet with 4GB Memory
I am trying to reset my d2 pad, but mine doesnt have volume keys
I have no volume keys, so how could I reset my tablet without volume keys
Lost password Nobis 1022C what do I do.
I already answered you. You need to do a Factory Reset.
  • How to reset 9" nobis tablet to factory setting? - How do ... www.askmefast.com > Consumer Electronics > TVs > Reset Nobis internet table recovery mode. You can perform a factory restore on the phone to get back in. power off phone, then boot into recovery mode by holding volume up ...
  • Nobis 9" Tablet 8GB Memory Dual Core - Walmart.com www.walmart.com > ... > Nobis 9" Tablet 8GB Memory Dual Core Nobis 9" Tablet 8GB Memory Dual Core. ... I have called customer support twice and performed a simple reset and a factory ... I went on the Nobis site to look ...
  • How to I factory reset my nobis 7" tablet? - Ask Me Fast www.askmefast.com > ... > Reset Factory reset nobis pad. The volume keys wont navigate when trying to factory reset my tablet? ... How to i factory reset my nobis 7 tablet?
  • Apr 03, 2016 | Tablets & eReaders
    How do i fix my hp tablet stream7 that has a black screan
    You can try a factory reset, try holding the power button and the volume down key on the side of the tablet then use the up and down voulum keys to select factory reset and push the power button. That should bring up a screen that says are you sure? Use the volume keys to select yes and it should reset. If this doesnt work, you have to get ahold of hp customer service.
    Jan 25, 2015 | HP Tablets & eReaders
    I am trying to fix a friend's digital2 tablet the s/n is m961gpl1312 and every time it starts up it goes to the Android recovery page and I've tried to factory reset it and then restart it but it still...
    you probably will need to update the firmware
    D2_961 Firmware Update Instruction:
    1. Download the D2_Firmware in the link below
    2. Use an archiving software (Winzip, WinRar, 7 zip etc.) to extract the Firmware Update package and export it to your computer's local disk (ex. C:\)
    3. Open up the zip file and there will be 3 folders as shown in image
    4. Open "Pad Product Tool 1.05_02" folder and click on "setup.exe" to install update tool.3-284x233.png4-284x233.png5-284x177.png
    Click "Next" all the way until the program starts installing. Click "Close" when the software has done installing.
    6. Click the 7.png icon and choose the firmware file "jellybean_atm7029_m2909_131216.fw" from the "FW_m2909_961_1115_1216" folder.
    7. When the firmware file loads, it will show up on the PAD Product tool.
    8. Now, click and hold down the "Volume - "key on the tablet.
    9. While holding down "Volume - " key, connect the tablet to a PC using the USB cable.
    10. Still holding down "Volume - "key, use a paper clip (or a small pin) and press the "Reset" button on the back of the tablet ONCE (and let go)
    11. The 9.png icon will turn into 10.png . Click it to start the firmware update.
    12. After the update is complete, remove the USB cable first, then turn on the tablet.11.png
    13. The initial start up time may take up to 50+ seconds.
    14. After initial start up, tablet will require a reset. Please press and hold the reset button for 10-15 seconds to reset the unit.
    http://cloud.d3reaction.com/public.php?service=files&t=2ff2083703cca9cfa4050bd47a793864&download
    Jan 19, 2015 | Digital2 Tablets & eReaders
    I forgot password on my RCA tablet. How can i reset it? I need a hard reset, how do I do that?
    While it's turned off you hold the volume up and power buttons. Then when the android appears release the buttons. Hold the power button and press volume up. Navigate with the volume keys and select factory data reset. Hopefully this isn't the method you'd already tried.
    Sep 15, 2014 | Tablets & eReaders
    Disco sound system diagram
    Go to Settings > Sound > Volumes, and slide the bars right. Alternatively, push the top half of the 2nd button on the top right side of the tablet.
    Mar 28, 2014 | ASUS Tablets & eReaders
    Tmax 9 tablet stuck on boot screen
    1. Shut off tablet
    2. press the volume minus button and the power button @ start up
    3. tmax logo shows up and then a android menu
    4. factory reset
    5. Once complete, reboot
    6. wait 4-5minute... tablet works again
    Dec 26, 2013 | Tablets & eReaders
    D2 PAD problem sound,volume set 100% but working like 10%
    I had the same problem and then the sound quit completely. sent in a service request and they replaced it. Just got the replacement this past week and set it up the weekend and no sound at all. Seeing as I purchased this in March and have still not gotten any use out of it, it would be an understatement to say I'm pleased with the d2.
    Mar 09, 2013 | Tablets & eReaders
    Wont start up the screen only displays the android logo i've tried pressing the reset button many times but still the same
    Try a master reset:
    • Turn off the unit.
    • Plug the unit into an electrical outlet.
    • Take a microSD card out of the slot. (Empty the microSD card slot.)
    • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
    • Release both buttons once the phrase "upgrade system activated" appears on the screen.
    • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
    • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
    • Wait until it finishes making a partition and shut down the system automatically.
    • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
    Oct 08, 2011 | Coby Kyros 7" Touchscreen Tablet
    Digital2 7 inch Tablet with 4GB Memory Logo
    110 people viewed this question
    Top Digital2 Tablets & eReaders Experts
    ka4iup
    ka4iup
    William Alequin
    Gil Shultz
    Are you a Digital2 Tablet and eReader Expert? Answer questions, earn points and help others
