Question about Canon MultiPASS F60 All-In-One InkJet Printer
Error code 335
Says it has a scanner problem as soon as you start up the alarm light is on.    Then of course it goes through the rest of warmup. Shows date and time, then flashes back to error code.Optics do move during warm up. But there is no green light.
    Scholar:
  • 151 Answers
The error is Data transmission error between the system control section and printer control section.
May be these are the problems: Look around it:::
>>Don't waste your time with Service Mode. All you need to do is take out the ink cartriges while computer is on (it will now start blinking cartrige jam) turn off printer & turn on again. Place cartriges back & press stop/reset button. Then turn off & turn on again and printer is back on line. No more flashing orange.
>>The data cable that attaches to the printer head is also attached to the back wall - make sure it is firmly attached and if not take it off and redo it/ Solved the error message instantly..
it is a communication problem between scnt system board and pcnt print control board. It can teardown and rebuild in 20 minutes. the waste ink tank is not a tank it is a strip of sponge material in the bottom of the printer. the printer calculates when it should be full based on how many print jobs vs your ink useage. the clear codes should have solved the problem on most printers. the part is listed as replaceable canon part #QA4-0662-000. the canon website has a phone number for replacement parts.
Hope this will solve your prblm
All the best
Posted on Oct 18, 2007
How can rest the computer alarm manualy to cancel the fualty alarm like engine service soon
A check engine light usually isn't a faulty alarm. You should have the computer scanned and the cause for the light to come on repaired. However, disconnecting the battery will usually clear the code.
Sep 16, 2010 | 2000 Suzuki Grand Vitara
Had bad ignition coil replaced in Nissan Sentra 2001. Error code 300 and 335 were prevalent. After replacement had Camshaft Sensor replaced, still get error code 335. Thinking maybe one more ignition coil...
please have a test performed to confirm the integrity of your head gasket. this era of these cars were prone to failure, causing coolant to leak into the cylinder thus a misfire. it is typically most noticeable on a cold start, and can cause long cranking times, as well as a rough idle when first started. good luck!
Jul 07, 2010 | 2001 Nissan Sentra
MW511 top loader washing machine. 3rd & 4th LED lights are lit and beeping sound is heard. When Start/Pause id pressed, the above lights go out and Lid Locked lamp comes on. When Power button is...
The third and fourth lights from the left indicate a failed motor controller (error code 48) If this is the correct fault code you will have to replace the motor controller. However before that is done all the electrical components which can effect the controller must be checked as well...Best to call a tech...Good luck Nomess
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
Have a 2002 Ford F150. Service engine light soon is on. Is there a way to manually pull the codes?
On my 02 ford pu, if you have the digital odometer, I hold the odometer/reset button down while starting engine, it goes thru test and gives error codes. Disconnecting negative battery cable for a minute, then reconnecting, will turn off the light if there are no issues.
Mar 05, 2010 | 2002 Ford F150 Regular Cab
Oki b6200 has an error code of 006 335
This error code is associated to the scanner unit, try cleaning it
Apr 09, 2009 | OKI B6200 Laser Printer
SERVICE ENGINE SOON
The codes all have to be cleared by using a scanner but if the reason the light was on has not been fixed the light will just come back on. If the problem has been fixed the light will go out on it's own after 25 warmup/cooldown cycles. Autozone will read the codes for you free of charge but they will not clear the codes to shut the light off. You either need to buy a scanner or take it to someone who has one. Good luck
Dec 23, 2008 | 2001 Chevrolet S-10
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Hp photosmart 335
Talked to HP tech support today- the "Tech" said these errors are "internal hardware issues". Since HP has "no service locations for printers"- The only solution is.... TO BUY A NEW PRINTER! (of course $$$) Why did we not think of that!
Rest In Peace
HP Photosmart 335
2002-2008
Jul 23, 2008 | HP Photosmart 335 InkJet Printer
To get ride of Canon Pixma MP160 Service error 5010.........!!!
Pliz help me out and fix the service error 5010 which i get as soon as i turn on my printer and due to which the alarm light starts blinking, i'm helpless coz either my printer or Scanner isn't working, so pliz stretch out your helping hand in order to let me get ride of this.
Regards,
PRINTER DOT COM
Feb 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon MultiPASS F60 All-In-One InkJet Printer Logo
79 people viewed this question
old marine
old marine
