Music Logo
Posted on May 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello do I would like to under stand what the buttons on my Behringer ULTRA-DI DI100 Direct Box do
Michial Gueffroy
Level 3:
President:
  • Master 1,140 Answers
  • Posted on May 19, 2009
Michial Gueffroy
Master
Level 3:
President:
Answers
1140
Questions
0
Helped
532741
Points
2214
Do you have the owners manual? If not you can download one from Behringer for free. The manuals are in pdf format and come in several languages.Go to Behringer, click on products, click on DI boxes, click on Ultra DI-DI100, look towards the bottom of the page and you will see DI100 Manual, click on the language you prefer( in my case it was English). Do you have a specific question about the manual. It is pretty concise and gives you a couple of setups for an example. Follow the directions closely and you won't hurt your equipment. Hope this helps.
BEHRINGER ULTRA SHIFTER US600 with EXPRESSION pedal, has pedal problem.
Question edited for clarity.
Question moved from Motorcycles Category.
Sounds faulty. Contact Behringer Support
Product ' US600
Behringer https://www.behringer.com > product
The US600 stomp box offers 5 totally unique Modes: Tremolo Bar, Flutter, Detune, Harmonist and Pitch Shifter. Pitch Shift and Tremolo Bar pitch can be shifted ...
https://www.google.com/search?q=Behringer+us600+%2B+expression+with+Nektar+NX-P
My behringer um300 pedal won't turn on when pressed. the sound goes through, but any slight movement makes a loud, scratchy sound.
It's probably the activate button. Maybe it is stucked, but more probably that is damaged so when you tap it with your feet, it's making these sounds...
If you don't have any or very small experience in electronics, then take it to the electronics service center for electronics engineers to look it up,
Cheers!
Where can I get the schematic for a behringer DI100?
There are a few images and some info online, although nothing very conclusive? I would try contacting the company, I do amplifier repair and deal with company's daily, most of the time they are more than helpful...
http://www.behringer.com/EN/Support/index.aspx
2answers
Factory reset Behringer FBQ2496
After my FBQ 2496 began to go "wild", it finally went blank with a ticking sound. I tried pressing and holding the "Reset" and "Bypass" buttons, simultaneously during power on. It worked after 3 or 4 tries.
Direct out kills speaker signal on my behringer bx1200
If it's still under warranty, get it replaced. Otherwise, take to an authorized behringer repair shop, or your local pro-audio repair shop.
Can't get cd player to work in my ub802 mixer.what am I doing wrong.I have connected it via RCA cable from cd player to mixer tape in .is this correct.I also have the mixer in tape out and phantom...
Phantom should ONLY be on if using CONDENSER mics or a DI box requiring phantom power... yours should be OFF. cables should be correct. The 2 Trk to mix button should be down.
I have a condenser mic, and it needed phantom power to work, so I bought the Ultra Di-100, but I don't know how to make my mic work with it.
Sorry, but the DI-100 can OPERATE on phantom power, not supply it. If you have a mixer that has phantom power then you have no need for the DI box. DI boxes are to convert unbalanced signals to balanced to send via XLR or TRS cables.
If you don't have a mixer that has built in Phantom power or a source of Phantom power, then you need a mic preamp that can supply the phantom power.
Here is an example device, but DO shop[ around as you should find some even less expensive. Make sure they have phantom power.
http://www.amazon.com/M-Audio-Audio-Budget-Microphone-Preamp/dp/B000CZ0RZG
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
