Question about Northpole Lionel North Pole Steam Engine Whistle Train Locomotive
Www support toys1628 com
Steam smells like burning wires
    Sergeant:
  • 236 Answers
Check that you have added the smoke fluid (oil) to the engine and that it has not run dry. The smoke from the engine is generated by a small chamber with a heating element built in. The heating element gets hot as the loco runs and heats the smoke fluid up which in turn creates the steam/smoke. If there is no fluid the heating element can over heat and will smell as you describe. Not sure if your model has a smoke effect on/off switch, if it has switch it off if you do require the smoke effect.
Posted on Jan 20, 2014
My microwave is steaming and my whole house stinks. how do i stop the smell and is my microwave broken or is it alright to use?
I guess the question is, what kind of smell is it? Is it like rotten food? Is it like burned wires? If you are not sure, ask a friend to help you identify the smell. Any burned smell is telling you "Get rid of the machine RIGHT NOW before it catches fire".
Other smells that are not so bad can sometimes be helped with a good "airing out" and the addition of a pile or box of baking soda inside to absorb the smell. Do not turn the machine on with the baking soda inside. Air it out outside or in an area that is not living space.
God bless your efforts.
Jun 01, 2015 | GE Microwave Ovens
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
2003 jeep grande cherokee white smoke from drivers side of hood
old post
smoke or steam.?
smoke lingers long, steam goes away fast
steam smells like antifreeze, sweet and nasty
smoke smells like, well, oil burning,
take eng. dip stick drip one drop of oil on a hot manifold
smell smoke, now.
Feb 20, 2014 | 2003 Jeep Grand Cherokee
There is white smoke coming out the tailpipe no smell of antifreeze
If it doesn't smell like sweet then you most likely got a bad tank of gas. Just to be safe keep an eye on your engine temp. and coolant levels.
Mar 26, 2011 | 1993 Dodge Intrepid
Smoke coming through air vents
Is it smoke? Or is it steam? If it's really smoke, it will smell like burning wires and you have an electrical short somewhere. You're going to have a fire unless it's fixed.
My guess is that it's probably not smoke or you would have already had a fire.
With that said I'm going to say that it's steam in which case your heater core (which is a small radiator located under the dash) is leaking coolant and the resulting steam is rising through the vents. The steam will have a sort of sweet and yes, a steamy smell to it. It will also leave a funny film from the radiator coolant coating the inside of the windshield.
The heater core should be replaced if my assumptions are correct.
Dec 27, 2010 | 2000 Dodge Neon
Coolant smell with steam
where ever u see the steam is ur leak-- steam is the coolant burning off usually wont show a puddle unless hose leak,or pump leak-- if the steam coming from tailpipe possible head gasket went
Feb 23, 2010 | 2000 Mazda 626
The steam coming out of my espresso smells burned
Try descaling amchine to clean boiler.
Mar 12, 2009 | Saeco VIA Venezia
Smoke coming out of vent when defoster is on 99 chevy blazer
what does it smell like? antifreeze, burning wires, oil, no smell, here is my best guess, 1- heater core, 2- heater blower motor burning up, 3- engine oil, and 4- steam condensation, 5- a ghost.
Feb 02, 2009 | 1994 Chevrolet S-10 Blazer
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Burning smell
We had the same problem. After we used it a few times, the smell went away.
Jul 06, 2008 | Whirlpool GGW9250PL Gas Dryer
Northpole Lionel North Pole Steam Engine Whistle Train Locomotive Logo
147 people viewed this question
Top Northpole Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Northpole Craft and Hobby Expert? Answer questions, earn points and help others
