H2 error code in cristal wash machine
Crystal dwd f1031
Coldcut
  • 1554 Answers
SOURCE: error codes
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
Posted on Jan 29, 2008
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
Posted on Feb 22, 2008
SOURCE: dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Posted on Jan 11, 2009
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
jmeredith
  • 417 Answers
SOURCE: My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Posted on Nov 27, 2009
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
How to change the switch door lock
What is the model number of your unit?
Nov 02, 2012 | Daewoo DWD M1031
What meens E8 error at crystal DWD-F2011W
the coal of motor is finished , you must to change the coals
Apr 10, 2011 | Whirlpool Washing Machines
I have problem whit Toshiba 5005-S504.My Windows Xp was **** and i try to reinstall but the notebook can't boot from enythink. I try whit standart way by DWD rom but dwd can't read the disk whit...
Hi, you will have to change the boot sequenc.when you turn on watch the screen and you will see very quickly to press F2 or a different key to go into the bios. I think it is on the first screen to change the sequence - Boot from cdrom then hard drive.
Then insert your dvd and install, if you need more help, please ask.
Jan 30, 2010 | Toshiba Satellite 5005-S504 Notebook
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Washing Machines Logo
Top Washing Machines Experts
