Question about Zoom H4 Handy Recorder
Zoom h4 freezes at the home screen
It stays frozen even when turned off
Where could I get the Zoom H4 service manual or circuit diagram?
Samson or Zoom will not release there technical papers unless you are a authorized service center
May 24, 2017 | Zoom H4 Handy Recorder
My Zoom H4 Handy Recorder will not power on?
The H4 has a problem with the inside back circuit board disconnecting from the main board. For that you have to take it apart.
Pretty easy for anyone technically inclined. If I remember, 4 screws.
Carefully, of course. Inside you will find the back board (where the power and audio inputs are) unplugged from the main board.
Plug back in, and put some kind of piece of rubber or even cardboard (I did that) retainer to put pressure on and avoid this happening again.
It is a design problem, I had to find out myself.
Hope this helps, please let me know...
Enjoy !
Jul 04, 2015 | Zoom H4 Handy Recorder
How to perform a factory reset on zoom H4
Hello ! Actually what you do is download the latest firmware from the ZOOM page. Find HANDY H4 (you can Google that) and go to the Download tab. Follow all instructions. Be sure to have new batteries or be plugged in to AC while you reset. I've done it on my H4(I have 2) and H4n and it worked fine. Be patient, it takes a while once you start. Good luck !!
Mar 09, 2014 | Zoom H4 Handy Recorder
My Zoom h4 has been struggling for a couple months now. Most of the time I get either an error message concerning the card or saying the card is full. Even when the card has been reformatted both on my pc...
Make sure the batteries are good... some people try to use re-chargeable batteries and because of their lower voltage they cause problems. First thing is to try new batteries.
Feb 12, 2011 | Zoom H4 Handy Recorder
I have a h4 recorder and when i turn it on i get a no card reading .changed card still same message
Are you using the type of card recommended in the manual? There's also an update here that you might like to have:http://www.zoom.co.jp/english/download/software/h4.php
Sep 11, 2009 | Zoom H4 Handy Recorder
H4 zoom battery operation
try resoldering the circuit board where the power socket is ... as there is a switch on the socket that disconnects the batterys
Jul 02, 2009 | Zoom H4 Handy Recorder
Zoom H4 does not power up on battery power.
Probably two years too late, but I recently got a used H4 and it was having this same issue. Upon reading the documentation, it seemed as though it required a specific type of AA batteries. If you update the firmware (mine was 1.3) to the latest version (currently 2.4), you can toggle the battery type under the menu (most likely alkaline is what you want). It also added lots of other great features!
Jun 02, 2009 | Zoom H4 Handy Recorder
H4 isn't recognised by my Mac as an audio device of any kind. It doesn't even connect properly.
There is a page at http:// www.zoom.co.jp/english/download/software/h4.php that may help you. It is supposed to fix the usb audio interface problem. Hope this helps.
May 24, 2009 | Zoom H4 Handy Recorder
I am trying to install the Zoom H4 with Cubase LE4. Can't
Sounds like it's time you upgrade to a core 2 or better computer.
Jan 06, 2009 | Zoom H4 Handy Recorder
Can't connect the h4 handy recorder to a mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4  firmware from Zoom website
You will need an external SD card reader.
Good Luck
Nov 18, 2008 | Zoom H4 Handy Recorder
Zoom H4 Handy Recorder Logo
37 people viewed this question
Top Zoom Music Experts
Michial Gueffroy
Barry Webster
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
