Question about Sangean WR-2 AM/FM Radio
No sound. Brand new. Out of the box it worked great. Tried to set the time and the sound quit.
  • Sangean Master
  • 8,016 Answers
Read the manual. The radio may have been set to some defaults, although the time was not correct. When you started setting the time, it is possible that you should have run through the whole setup. For example some radios have different ranges for the FM bands: there is a Japanese band that starts at 76 MHZ, and ends at 108 MHz; there is the standard FM band from 88 MHz to 108 MHz; and a school band (I can't remember its range).
For AM the gap between neighboring positions may be set at 9 kHz or 10 kHz depending on the location (region or continent).
I suggest you get the manual and see if there is an initial setup procedure, then follow it.
Posted on Feb 03, 2014
Toshiba 65h14
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Aug 09, 2014 | Toshiba 65HX81 65" Rear Projection...
I have an old samsung tv in great shape the tv shows it's getting power but the power indicator is flashing 6 times then turns on with no picture and no sound I want to know what the 6 flashes mean any...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jul 03, 2014 | Televison & Video
Sled4668w tv scans channals but always shows 0 found hooked upto dish network
This Orion TV made by Sansui was bought by me two weeks ago. It didn't last a week. The sound was terrible, picture was great, and it wouldn't hook up to soundbar without hearing a long delay in sound (A/V or Digital output tried two). I contacted their customer support twice, they were awesome. Told me this model has know issues and said to just bring it back. I found another TV for same price ($399) and same size (46) but it's LCD not LED, better picture and great sound! It is Insignia don't remember the model #. Bought at Best Buy (their house brand).
Feb 22, 2013 | Televison & Video
Quit moving
Have you tried replacing the battery?
Jul 19, 2012 | Citizen EcoDrive Calibre 8700 IonPlated...
Can get great hdmi picture but no sound
HDMI very commonly creates loss of sound problems. A few suggestions: (not knowing the model or brand) The first is that HDMI does not like it when connected with the unit/s powered up and on.
If from a Gaming unit disconnect and reconnect with unit off.
Also if from a cable or sat box do the same---unplug the box and hookup and hook up again and plug box back to power--see if a reboot will restore audio.
Not a sure thing but in our shop we use several set top HD boxes connected to sets being "cooked" or tested.
One day (first time I had seen it) we had 3 plasma sets running out of the same box---one had audio and 2 did not---all three were same brand and model---unplugging the box, waiting a few minutes and plugging back to power---box booted up and all 3 now had sound.
Other possible reasons can be ruled out if the HDMI works on another set etc.
Some sets will have a software/firmware upgrade available for issues like this also.
Best answer here with the information given.
Apr 14, 2012 | Televison & Video
During the past year, we've had to buy five converter boxes quit.
My DTA1050 worked OK. Then, after a period of non use, it would not work stating no signal. The antenna tests OK on a digital TV.
These things simply die, and Access has our government money!
Jul 23, 2010 | Insignia Digital-to-Analog Converter for...
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No sound from my brand new speakers
I am assuming you have tried new speakers on used unit on both A & B choices. Have you tried your new speakers with old 2802? If they work OK with old unit, you have problem with amplifier in used unit. Take the used 2802 to a reputable shop and have it thoroughly tested. Perhaps it is just a loose connection.
Dec 12, 2006 | Denon AVR-2802
Sangean WR-2 AM/FM Radio Logo
113 people viewed this question
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
