Question about Fujitsu Computers & Internet
Cmos checksum bad on my a series 3120
I cant remember the bios password so i cant reset the date or default settings for cmos need help
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 146 Answers
  • 85 Answers
SOURCE: bios password ibm thinkpad g40
Sounds like you tried this, but it's worth a shot again. Remove the CMOS battery on the motherboard and let the laptop sit for an hour, then replace the battery with a new one.
If the only real issue is changing the time and date, you can do this in Windows and it will reset the BIOS clock, too, of course.
If the problem is that the time and date keep reseting, you either have a low CMOS battery or a short on the motherboard that is resetting it.
If all else fails, you might need to flash the BIOS from a floppy disk with the latest BIOS version for your machine to reset it and go from there.
PS: BIOS reset problems on laptops are sometimes due to power problems caused by battery packs going bad; check your battery pack, too, and see if it is working okay.
Good luck...
Posted on Nov 16, 2007
SOURCE: BIOS Password
am not able to reset BIOS password even after removing the CMOS battrey. I need to change the boot sequence, please help.
Posted on Dec 06, 2008
  • 50 Answers
SOURCE: Reset CMOS password on IBM R32 Notebook
u need to put in the system recovery cd that came with the laptop in the dvd/cd drive and format the computer
Posted on Dec 22, 2008
Katwal
  • 129 Answers
SOURCE: reset password bios acer 4315
This can be done by visting vendor website.
Please download the BIOS update utility from the following web site. You need to select you machine model number under BIOS button u can get the utility to download.
Posted on Jul 31, 2009
SOURCE: IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
Posted on Sep 16, 2009
Dell Inspiron 530. At start up gives CMOS checksum error defaults loaded. Options press F1, F2 or F12 computer does not react. Has new CMOS battery. RAM OK. Did CMOS clear and password reset. What else can...
When a Power Supply is plugged into power, there is a constant 5 Volts present. The 5 Volt Standby Power.
You press the Power On button.
This in turn presses against the Power On switch, located inside it's plastic assembly.
The Power On switch is a Momentary Contact Switch.
Temporary closing it activates the Soft Power On circuit.
A 5 Volt circuit that utilizes the 5 Volt Standby Power.
The Soft Power On circuit 'excites' the Power Supply, and turns it on.
(Sounds like a seedy novel)
The first chipset (Integrated Circuit) to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
A checksum is computed as an error-detecting code, to protect the BIOS settings stored in CMOS.
Each time the computer is turned on, this number is re-computed; and checked against stored values.
If they do not match an error message is generated, to tell you the CMOS memory contents may have been corrupted; and therefore some settings may be wrong.
Your BIOS assumed the settings were incorrect, and loaded BIOS default settings; stored in BIOS.
(Default = factory settings)
CMOS Checksum Error Defaults - Loaded
New battery? Nope didn't help.
Clear CMOS, and password reset? Nope didn't help.
Leaves Virus as the problem, or hardware component/s on motherboard; are bad.
My thoughts?
Bad motherboard.
("BAD motherboard. NO,...........you know you have been bad,....don't give me that look. You're a bad motherboard."
Lol!)
That's my diagnosis.
(Unless you put the CMOS battery in upside down.
+ goes UP)
Regards,
joecoolvette
Mar 17, 2013 | Dell Computers & Internet
Cmos checksum error-defaults loaded
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program.
This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty.
It could also be another component on the motherboard.
Make sure the battery has plenty charge or remove the battery for a while, about 5 minutes to see if that restores it some motherboards cmos batteries are soldered in
You could check the site for the machine vendor to see if there is a reset jumper.
If that doesn't work then you will need to refresh the BIOS
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS.
To do that you need to press a key while the computer is booting Usually the Delete or F2 but can be other keys
It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one.
You will also need to reset the time and date.
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
Press F10 Save, Exit and re-boot and everything should then work
hope this helps
Aug 03, 2012 | Dell Computers & Internet
Bios rom checksum error, boot block bios vI.0
Error BIOS ROM CHECKSUM - SYSTEM HALTED.
Cause Bad Hardware
Solution Unfortunately this indicates that your computer BIOS ROM chip or Motherboard is physically bad. It is recommended that you contact your computer manufacturer or take the computer into local service center for repair.
If you wish to repair this issue yourself the motherbard will need to be replaced.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
hope this helps you
Apr 14, 2012 | ASUS A8N-E Motherboard
Bad check sum cmos
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
hope this helps you
Nov 18, 2011 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Cmos checksum bad boots to the splash screen then goes black with a blinking white line tried reseting the jumper cmos no luck load default settings no luck removed psu and battery no luck
hope this helps you
Oct 08, 2011 | EliteGroup ECS Socket Micro ATX...
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
I used jumper bios reset and now gettin bad checksum error. on the mother board writen that K8N rev 1.01 i downloaded k8n motherboard rom file and renamed as k8n.rom and copied to disket. its deleting and...
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
Jun 17, 2011 | ASUS Computers & Internet
Cmos checksum bad
Diagnosis: The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
hope this helps
don't forget to vote
Feb 11, 2011 | Computers & Internet
I've replaced the battery but checksum error still occurs and F1 is suggested to press for setting time and date
Hi, try this link it has usfull information and help, your problem may well be that your BIOS needs resetting back to default:
http://www.tech-faq.com/cmos-checksum-bad-error.html
Aug 03, 2010 | Mercury P4VM800M7 Motherboard
**** RTC battery is low or CMOS checksum is inconsistent **** Press [F1] to set Date/Time
Hello
Please reset cmos to factory defaults.
Then enter the bios setup and configure it and save changes.
Apr 20, 2009 | Computers & Internet
Computers & Internet Logo
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
