Question about DIGITECH RP90 Guitar Multi Effects Pedal
Digitech Rp500 will not boot up, lights that spell out text kind of hesitate like a bad marquee
Just got a new power supply, worked for months then this happened.
3 Suggested Answers
  • 1137 Answers
SOURCE: i need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
Posted on May 26, 2009
  • 5603 Answers
SOURCE: NO power light from Digitech Vocalist 2 live.
Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more.
Posted on Dec 23, 2010
My digitech 4 harmoniser is cutting out, have sent for a new power supply adaptor to see if this is problem any other ideas?
Most likely it is the power supply, but if you have a unit that uses the same voltage, you may want to try it. Another possibility would be the power input jack or where it is soldered to the board. If you're not comfortable working on those elements and the PS doesn't work out, take it to the shop.
Mar 06, 2015 | Digi-Tech Digitech Vocalist Live 4...
My Wawa pedal went out on my Digitech RP 500 how could I make it work again
This might work - Hold the bypass switch for five seconds and follow the on screen instructions to calibrate the expression pedal. If that doesn't work you could also try doing a back up and then a factory reset. You may also consider a separate wah pedal. There are many recommendations at:
What Is The Best Wah Pedal For The Money Our Answer For You
Jan 07, 2015 | DIGITECH RP500 Guitar Multi-Effects Pedal
Service manual schematics
If you open up the unit, you may be able to fix the jack if it has come loose and maybe got a broken connection in the process. It may just be a "cold solder joint" causing the problem
Sep 04, 2014 | DIGITECH RP500 Guitar Multi-Effects Pedal
Asus Monitor
Here are a few possible problems with your monitor
1, Backlight gone bad
2. Power Supply gone bad
3. Wrong display resolution
Given that your monitor is only 14 months old, I would lean toward
either a bad capacitor in the power supply or the screen resolution
needs to be changed (boot up in safe mode and change the resolution)
The power supply problem would require some dis-assembly and working with high voltage.Not for the faint of heart..
Jan 19, 2012 | ASUS Computers & Internet
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
NO power light from Digitech Vocalist 2 live. Power supply OK. Is there an internal fuse. etc? need tips to troubleshoot.
Dec 23, 2010 | DIGITECH VOCALIST LIVE 2
Computer won't boot up
Have you tried a higher rated ATX power supply? Preferably a 350w.
Apr 22, 2009 | ASUS SiS Chipset TUSI-M Motherboard
Digitech RP90 Expression Pedal
Same thing happened to me but i didn't drop the pedal.Try to recalibrate the pedal cause mine worked after that.Look in the Owner's Manual at the recalibration section.Hope this will work for you.Good luck with it!
Mar 29, 2009 | Music
DIGITECH RP90 Guitar Multi Effects Pedal Logo
98 people viewed this question
Top DIGITECH Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a DIGITECH Radio Communication Expert? Answer questions, earn points and help others
