Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire SY CF issues
On my Frigidaire model FGHB2844LF7, the ice maker jammed and broke. Now I have that fun "SY CF" error code. I see that I can replace the ice maker (part 243297603 is on its way). By replacing that part, will the fridge reset itself and no longer have a communication error? Is there a reset button of some sort somewhere for it to re-run communications? Thanks, -Jack
  • Official Brand Answer
  • 4,342 Answers
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Posted on Jan 03, 2014
SOURCE: Ice Maker water keeps running
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
Posted on Jul 22, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
SOURCE: Not making ice
the icemaker is not making ice,In the bottom of refridegerator you can see some coils and they are iced over bad.
Posted on Jun 04, 2009
I have a Frigidaire French door refrigerator model FGHB2866PF. Had ice jam dispenser. Display error code dl SP (dl SP). Cleared jam and emptied ice maker bin.
If you wish to get some details about refrigerator repair then check the following link ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 22, 2017 | Frigidaire Refrigerators
Frigidaire fridge model FGUN2642LF6 fridge is not working. Code displays sy and ef, what is wrong
Your evaporator fan is not spinning.
Check to make sure there isn't any ice build up jamming up the fan. If there isn't then it's either the evaporator fan, or the main board.
Aug 14, 2015 | Frigidaire Refrigerators
Code on door of French door reads error message 5y ce. sounds like it is still running but no light inside or ice maker not working.
Thank you for your post, Carol!
I understand that your Frigidaire refrigerator is displaying an error code of "5Y CE". However it appears that "5Y CE" is an invalid error code. I have noticed the code of "SY CE" and that means there is a communication error at power up. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue it could be possible that there is an issue with your main control board, wiring harness, or user interface board. I would then suggest having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
May 19, 2015 | Frigidaire Refrigerators
Fix my problem get sy cf on my display
Hello Eric espy, thanks for your post!
From my understanding you used the icemaker on your Frigidaire refrigerator and now have a code of "SY CF" on the display. That code of "SY CF" stands for communication failure after power up. This could be a possible communication error between the UIB (User Interface Board) and main control board. I would suggest performing a reset, which should clear any false error codes. If you continue to receive the error I would suggest contacting a professional technician for proper diagnosis and repair. This may help you avoid unnecessary part purchases. -Matt
Feb 22, 2015 | Frigidaire Refrigerators
What does an O F fault code mean on a frigidaire refrigerator mean
Sounds like off to me. An open sensor will be displayed in either the ff display or the freezer display. if it is an open freezer sensor it will display in the freezer display. A communication failure will show as a SY CF, and a communication error will display a SY CE.
Feb 18, 2015 | Frigidaire Refrigerators
I have a Frigidaire gallery refrigerator with a error code 5y cf I put in new ice maker and a new control board still have same code anybody got any sugstions plase
hello jon;
my name is peter. i am a retired field service refrigeration technician.
cf= cooling fan. is your freezer fan running? is the back wall of your freezer section iced up? is your fresh food section cold?
send me your model number. it is on a label, on the inside wall of your fresh food section near the top.
Jan 21, 2015 | Frigidaire Refrigerators
My frigidaire refrigerator reading cf and water and ice maker do not work.
Good Morning jesse, I appreciate your post!
I see that your Frigidaire refrigerator is displaying an error code of "CF". Normally, "CF" stands for communication failure upon start up. I would recommend performing a reset on your refrigerator and you can do that by disconnecting power from it for ten minutes. If you continue to experience this error code it could be a possible problem with your user interface board or main control panel and I would suggest contacting a technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Nov 23, 2014 | Frigidaire Refrigerators
How to fix Sy cf code
Good Afternoon Friend,
I understand that you are receiving an "SY CF" error code on your Frigidaire refrigerator. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. If further troubleshooting is needed, I ask that you please supply the model number of your refrigerator. Typically, you can find this number inside the refrigerator on the cabinet all. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Refrigerators
My frigidaire is displaying SY CF
Hello Angela Clark - Typically error code SY CF indicates that the refrigerator has detected a communication failure after power up. Contact a professional to move forward accurately. The wiring between the main control board and user interface board will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Dec 05, 2012 | Frigidaire FGHB2844L
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
737 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
