Tv picture changes and recording is unwatchable when trying to rec one of 4 local channels
I have a vcr/dvd player and Comcast non HD basic cable,unit has worked fine until recently. When u try to record one of the 4 local channels the tv picture turns dark red and jumps around and the play back is unwatchable. It works perfectly when recording all the other Comcast channels and will play all other tapes. Ive tried everything but cant figure it out, Comcast says they detect no issues with our signal or their box. I think it has to be the cable because the unit works fine except on the 4 local stations.
    Master:
  • 796 Answers
It is the signal from the 4 local stations that is the problem, because you can record all others ok. Borrow another VCR and try to record them, if its the same tell the people who run the local channels that they are losing viewing figures, because their channels cannot be recorded.
Posted on Dec 28, 2013
3 Suggested Answers
SOURCE:
vikkisuri
  • 46 Answers
SOURCE: Plus! Analog Recorder
might be u have changed the format of recording the cd players support only selected formats only like mpeg 4 mp3 divx etc u might have wrong set the recording format to some other format like wma,dat,avi etc just check the seetings of the software
Posted on Nov 22, 2007
griffinkec
  • 46 Answers
SOURCE: LVW-5045 gdl+ liteon dvd recorder
Does it burns other cds,Try installing the drive drivers again and run system restore utility.That should fix things up.Cheerio!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Feb 04, 2008
Troubleshooting vcr/cable box
Seriously? You are still using a VCR?
Feb 03, 2018 | Computers & Internet
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Will not record digital channels
first make sure the cable is running through you vcr then make sure you vcr is set to either channel 3 or one of the inputs
May 06, 2009 | Philips MWD2206 DVD Player/VCR
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
Not able to scan stations
I don't understand why you would bother to scan channel when you have directv or dishnetwork???
directv or Dishnetwork required their units in order to watch any channel,which means:
A. Depending on your TV setting,if you use RF connection from your basic directv to the tv,you would have to leave the TV on Ch.3 or Ch.4.to view the rest of the channels,you have to change it from the directv or dishnetwork box. You are NOT able to scan the rest of the channels from the TV,bottom line!!
If you have comcast or your local cable provider,once you have activated,you could use the RF signal coming out from the wall plate straight to the tv and go to TV auto programming,it will auto scan the available channels for you.
Don't waste your time on directv.
If you are thinking about recording from your BASIC directv or dishnetwork box, you would connect SAT. signal from the wall plate to the directv box,then use composite video/audio output and connect straight to your VCR/DVD player under composite video/audio input. Now you could record the viewing channel to the VHS.
Aug 19, 2007 | RCA DRC8335
Can't tune cable box to channel 2 to set up TVGOS
then you can try channel 3 or 4 if that does not work then you have to replace for a latest tv that does not use cable box.thes out of style
Mar 02, 2007 | Panasonic DMR-EH75 DVD Recorder/VCR/HDD...
Computers & Internet Logo
48 people viewed this question
Ekse
Alun Cox
