Question about Viper Vehicle Parts & Accessories
Revtech accelerator 2 carb diagram - Viper Vehicle Parts & Accessories
Weber carb accelerator pump diagram needed . Not pumping .. anyone? ??
We go by model and year. But suggest you goggle how to rebuild a model ______ weber carb.
Jul 15, 2014 | Cars & Trucks
Spark plub gap for revtech engine 100cid
Spark plug gap will be determined by the spark plug make and type etc. I recommend only H-D plugs in H-D bikes but ...........
Apr 20, 2014 | 2003 Harley Davidson FLSTC Heritage...
Revtech starter diagram
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your BMC but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Revtech starter diagram Google Search
100 Rev Tech Starter Problem Club Chopper Forums
Starter Replaced Still won Start HELP Twin Forum Harley Davidson Forums
Servicing rebuild your starter motor
http://fullmanuals.com/brand/bmc-choppers
Mar 03, 2014 | 2011 BMC Choppers Hooligan 541
Revtech 110 misfires at 3500 RPM
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor contaminated, sticky float, plugged jets.
13. Carburetor vacuum diaphragm torn, cracked, not seated or installed improperly.
14. Multiple carburetors out of sync.
15. Fuel filter clogged.
16. Old or contaminated fuel.
17. Fuel tank vent system plugged or carb vent line closed off.
18. Gas cap diaphragm valve faulty.
19. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
20. Carburetor controls misadjusted.
21. Incorrect valve timing.
22. Valve springs floating, weak, or broken.
23. Damaged intake or exhaust valve.
24. Incompatible performance parts.
25. Control module may be in "LIMP" mode
26. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
That misfire feeling Harley Davidson Forums
Engine misfires at low speeds
http://www.ultimaproducts.com/RevTech.pdf
http://www.hs-choppers.cz/katalogy/customchrome/09_CC_08.pdf
35078 CHROME REVTECH HIGH PERFORMANCE MAGNETIC LONG SPIN ON OIL FILTER...
Aug 03, 2017 | Motorcycles
Revtech 110 ON custom bike not sportster blowing oil through the carb
Your RevTech engine is a copy of an H-D Evolution engine. Just as with the Harley engine, it vents it's crankcase pressure through ports in the heads. There are "umbrella valves" made of rubber in the center section of the rocker box covers. These valves are made of a rubber like material and they will harden with repeated heating and cooling. If they get hard enough, they may not work as well as they should. This system does a fair job of removing the oil mist from the exhausted air but there is still some oil left in it. This oil will accumulate in the breather and drip out. You must clean the inside of the air breather occasionally to prevent this. However, if too much oil is coming out, you may have too much blow by on the rings or your breather gear in the cam chest may not be doing as it should. Harley uses a plastic breather gear and I've seen them break a tooth and stop turning. I don't know if RevTech uses a plastic gear or a metal gear. It depends on how much oil is coming out of the breather as to whether or not you have a problem. There are kits available aftermarket to reroute this vented air pressure outside of the air cleaner.
Good Luck
Steve
Jun 03, 2011 | Harley Davidson XLH 1000 Sportster...
I need a wiring diagram for rev tech m/c ignition
Hi Jstone1171, for more information on your question please visit the websites below and good luck:
wiring diagram for revtech motorcycle ignition Google Search
Mar 23, 2011 | 2000 Harley Davidson FXST Softail Standard
Echo cs302s chainsaw. It won't accelerate, it idles but can't adjust carb to get it to run . While I'm adjusting the carb,every now and then it will accelerate for a few seconds and then back to idle. The...
have you asked them? this website might help.
http://www.echo-usa.com/documentation.asp?Model=cs302s&lang=E
Diaphragms can develop tiny pin holes but i would expect this to cause it to stall rather than fail to accelerate.
The manuals and part diagrams may lead you to the fault. I would suspect the fault to lie in some kind of idle switch or other safety switch. It's one of those faults that are easier to diagnose when it's in your hands
Jan 19, 2010 | Echo Garden
I am having iol coming out of the top and side of
#1 its a made in Korea Rev Tech Head.
#2 It certainly is a gasket problem. You can't see the gasket until you take it apart. Maybe someone forgot to put in a new o ring. anyway get an upper end gasket kit. and torque it down properly.
Apr 05, 2009 | 2000 Harley Davidson FLSTC Heritage...
2006 revtech not getting any juice to my coil anyone have a wiring diagram? start button doesnt work, either.
Try to "chase the Gray wire from the circuit breaker to the connector to the on/off switch to the starter switch to the w/blk wire back to the connector to the coil
Apr 03, 2009 | Harley Davidson FXST Softail Standard...
Vehicle Parts & Accessories Logo
74 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
