Question about Apple MD368LL/A WiFi / ATT 64GB iPad 3 - Black
How do I remove the back.
The aluminum is bent at a corner from a fall. I'd like to straighten it out before it damages the screen.
    New Friend:
  • 14 Answers
Only way is to take it to an apple store and get it fixed , sorry .
Posted on Dec 30, 2013
Tablet touch screen is only cracked on the top right corner. What can i use to get the screen to respond to touch on the lower half of the screen?
You may have only cracked the top corner , but if the lower part of the screen is not responding then you have also damaged your digitizer. A replacement of the screen and the digitizer may be necessary.
Feb 06, 2016 | Tablets & eReaders
How do i fix my asus tablet its froozen on screen cant turn it off
Take a flat object like a butter knife, start near a corner and pop the back cover loose...then work your way around removing the cover, pull the battery out, press and hold the power button for a few seconds, put the battery back in, put the cover back on, turn the tablet back on.
Feb 17, 2015 | ASUS MeMO Pad HD 7
I have done all the fixes for the Samsung Galaxy Tablet 10.1 to resolve the black screen. I unseated, reseated the battery, disconnected/reconnected the LCD cable tape 6 times, I did power button.soun
I think it's just broken from the fall, man. It sounds like a pretty serious fall. If it's new maybe you can call the retailer to see if they can fix it for you.
Feb 06, 2015 | Samsung Galaxy Tab 101 Tablet...
How do I repair the USB PORT on a ACER ICONIA B1.
Step 1 - Back Case
  • To start, gently separate one corner of the case using the black spudger.
Step 2
  • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Step 3 - Battery
  • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
Step 4
  • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
Step 5 - USB Port
  • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
Step 6
  • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
Step 7
  • Disconnect the blue cable by gently lifting the flap.
  • Remove the indicated 2mm screw holding the speaker in place.
Step 8
  • Pull up the metal panel just enough to allow access, then remove the USB port.
Oct 29, 2014 | Acer Iconia B1 7-Inch Tablet Black Dual...
My tablet fell, it's not coming on
Maybe the screen is damaged due to the fall.Take it to a repair center.
Jul 27, 2014 | Samsung Tab Tablets & eReaders
NO DISPALY AFTER FALL FRON 3FT. HEIGHT
go to service centre
hardware is misplace
if you are good in hardware
open the back panel and you;ll see set of parallel wire stuck in jack
remove it and put it back on same slot
be sure your tab is switched off
Mar 05, 2014 | ASUS Google Nexus 7 Tablet
It fell down from 3ft height since then no dispaly screen coming
You probably broke the screen or a cable popped out. I made a video on how I replaced the screen in one.
Drop the tablet
The screen probably will have to be replaced but the fall may have caused internal damage so that even with a new screen the tablet may not work without further repair.
Dec 30, 2013 | Supersonic SC-91JB 9-inch Android 4.1...
My samsung galaxy ce 0168 screen is not working anymore after 2 minutes turned on
Check that the charging port pins are not bent or damaged or corroded use a small needle to clean each individual groove. Replace the charger, suggest Staples or Walmart for the source.
Dec 05, 2013 | Samsung Galaxy Tab Tablet PC
My tablet screen is not clear. the display is blurry and pixelated. .
hi,
if there are no damages such as liquid or physical damage than you can call Samsung, and if you have the receipt - or date of purchase registered then call Samsung and see if it falls under the warranty
thanks
Oct 19, 2013 | Samsung Galaxy Tab 101 Tablet...
Apple MD368LL/A WiFi / ATT 64GB iPad 3 - Black Logo
44 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
