Question about Hot Wheels Toys
Hot wheels wall tracks power tower
The tower is weighing the bracket & pulling it out of casing, the casing is staying on wall.
3 Suggested Answers
cooper0365
  • 347 Answers
SOURCE: broken driver seat track bracket hinge assembly
track its self bolts on after u take the seat out turn it upside town and un bolt the track u can pick them up at any junk yard or salvage yard
Posted on Oct 09, 2009
  • 110 Answers
SOURCE: rear power window drive cable
hello there:
i think that you may want to go ahead and replace the actuator and motor this would solve the problem and keep from having troubles later on down the road it should come with the track cables and all i hope this helps you out ..... if you would please leave a review for me thanks sincerely D.Jones
Posted on May 30, 2010
Changing a car battery
Follow this procedure exactly
  • 1
    Place the Z4 in park and turn the engine off. Allow it to cool for a half hour.
  • 2
    Open the trunk. Pull up the removable carpet and flooring. You will now have access to the battery, on the right side seated in a bracket.
  • Remove the bracket with a screwdriver. There are a total of three screws, two on the bracket and one securing it.
  • 4
    Remove the positive cable from the battery using a socket. Place the cable to the side. Remove the negative cable in the same manner. Pull the wall out.
  • 5
    Lift the battery out of the vehicle. Batteries can weigh up to 70 pounds, so get some help.
  • 6
    Place the replacement into the bracket. Replace the three screws to secure the bracket to the battery. Connect the positive battery cable and tighten it. Repeat the same process for the negative
  • Custom Wheels
    Jun 14, 2012 | 2004 BMW Z4
    Can a sony bravia kdl-w40a12u be put on a wall thanks
    You need to use GOOD WALL BRACKETS which can hold the weight of the TV.
    Also the mounting on the wall must be firm with good foundation tower bolts.
    please check on the links below for some tips and ideas on wall brackets.:
    TV Wall brackets: http://www.regencyproducts.co.uk/
    http://www.espares.co.uk/parts/tv-and-audio/lcd/plasma-brackets/p/1459
    Jul 28, 2011 | Sony KDL-W40A12U 40 in. LCD Television
    How much does the Maxent MX-50X5 Tv Weigh? I need to put it on the wall but everyone asks how much it weighs so i can get the right mount.
    Weight:106.5 lbs according to plasma.com. i did simple websearch (boolian, example Maxent MX-50X5 Television+ weight) and the search came up with that. you may need to convert it to metric if your from outside usa. i would go with a bracket with a higher gross weight, and be sure to mount it where there are wall studs, the bracket will come out if not properly mounted and down will come your tv..
    Best of luck
    Oct 17, 2010 | Maxent MX-50X5 Television
    Rear power window drive cable
    hello there:
    May 30, 2010 | 2000 Oldsmobile Intrigue
    How do I change the rear shock on my 1999 Dodge Neon?
    1. Raise and safely support the vehicle.
    2. Remove the wheel and tire assembly.
    3. Unfasten the retainer(s), then remove the hydraulic flex hose bracket from the strut bracket. If equipped with ABS, the wheel speed sensor cable routing clip is also attached to the strut assembly bracket.
    1. Support the rear knuckle, suspension and brake components before removing the clevis bracket-to-knuckle attaching bolts. Do NOT allow the weight of the knuckle and related components hang without support when the strut is removed.
    2. WARNING The knuckle-to-strut attaching bolts are serrated and must not be turned during removal. Remove the nuts while holding the bolts stationary in the knuckle.
    1. Hold the bolt with a wrench, then unfasten the 2 clevis bracket nuts attaching the strut to the knuckle.
    Fig. Fig. 2: Location of the knuckle-to-clevis bracket bolts
    1. Carefully lower the vehicle, then open the trunk. Access to the rear upper strut mount-to-strut tower attaching bolts is through the trunk of the car.
    2. If necessary, remove the carpet from the top of the strut tower. Then, remove the rubber dust shield from the top of the strut tower for easier access to the upper strut nuts.
    1. Loosen, but do not remove the 4 upper strut mounting nuts. Then, while supporting the strut assembly, fully remove the 4 strut mount attaching nuts.
    1. Remove the strut assembly from the knuckle by sliding the knuckle out of the clevis bracket on the strut, then remove it from the vehicle.
    Carefully pull the strut assembly out of the vehicle
    To install:
    1. Position the strut back into the vehicle with the 4 studs on the strut mount assembly through holes in the strut tower of the vehicle. Install the 4 strut mount-to-body attaching nuts onto the mount studs. Tighten the nuts to 25 ft. lbs. (34 Nm).
    2. Install the dust shield into the opening on top of the strut tower. Install the carpeting back on top of the rear strut tower.
    3. Raise and safely support the vehicle.
    4. Install the knuckle into the clevis bracket on the strut assembly. Install the 2 clevis bracket-to-knuckle attaching bolts and nuts. Hold the bolts with a wrench while tightening the nuts to 70 ft. lbs. (95 Nm).
    5. Install the brake hose bracket to the strut bracket and secure with the retaining bolts. If equipped with ABS, the wheel speed sensor cable routing clip is also attached to the strut bracket.
    6. Install the wheel and tire assembly on the vehicle. Tighten the lug nuts evenly, in sequence, to 100 ft. lbs. (135 Nm).
    7. Carefully lower the vehicle.
    8. Have the toe checked and adjusted as necessary.
    Nov 05, 2009 | 1999 Dodge Neon
    My garage door will not stay down when I try to close it.
    IF THE DOOR CLOSES ALL THE WAY WHEN HOLDING DOWN THE WALL BUTTON AND REVERSES 6" FROM THE FLOOR WHEN NOT HOLDING THE BUTTON.
    I WOULD GUESS THAT THE SAFETY EYES ARE MOUNTED ON THE TRACK.
    WHEN THE DOOR CLOSES THE TRACK AT THE BOTTOM IS TOO TIGHT CAUSING IT TO FLEX AS THE DOOR GETS NEAR THE BOTTOM. WHEN THE TRACK FLEXES THE EYES ARE POINTING FURTHER AWAY FROM THE DOOR AND EVENTUALLY THEY ARE TOO FAR OUT OF ALINMENT AND THE LED WILL GO OFF - THE DOOR GOES BACK UP.
    SOLUTION: YOU CAN USE THE CLAW END OF A HAMMER TO TAP THE TRACK OUT A LITTLE WIDER - TAP NEXT TO THE WALL ON THE BRACKET THAT HOLDS THE TRACK TO THE WALL. MOVE THEM ABOUT 1/4" EACH SIDE.
    OR
    YOU CAN MOUNT THE BRACKETS TO THE WALL OR THE FLOOR.
    THIS SHOULD SOLVE IT
    HAVE A GREAT DAY
    Dec 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
    LiftMaster Garage Door Opener
    IF YOU ARE TALKING ABOUT THE ROLLER ON THE DOOR - THE TRACK IS TOO WIDE ALLOWING THE ROLLER TO COME OUT. USE THE CLAW END OF A HAMMER TAP THE TRACK MOUNTING BRACKET AT THE WALL TO MOVE THE TRACK IN CLOSER TO THE EDGE OF THE DOOR
    Aug 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
    I have Kitchen Aid Dishwasher Model # KUDMOITJBLO. We began having trouble with the top rack coming out of the brackets on the upper rack track. Kitchen Aid sent me 4 parts # 8268785. The problem is...
    I removed the tracks from inside the dishwasher.  Then I was able to carefully remove the endcaps (something I had not been able to do previously) carefully.  The existing broken wheels slid out and I slid two new brackets into each track.   If I attached the tracks to the rack first, I would not be able to clip them into place, so I first replaced the endcaps and then returned the tracks to their positions inside the dishwasher. Reattaching the upper rack is not difficult, but takes two people while I connected the left side, my assistant supported the rack on the right side.  I then connected the right side of the rack.  I slide the rack back and forth to macke sure that is worked smoothly.  We then loaded the dishwasher and washed our dishes as we had in the past.
    May 27, 2008 | Dishwashers
    Toys Logo
    50 people viewed this question
    Top Hot Wheels Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Hot Wheels Toy Expert? Answer questions, earn points and help others
