Router default passwords
Android starts to authenticate the signal strength goes from excellent to poor and never does authenticate
  • 4 Answers
You should check the encryption protocol supported by your Android system, and the one active in your Router, the should be compatable.
Posted on Dec 28, 2013
nyilasrobert
  • 627 Answers
SOURCE: how to reset Edimax BR-6204Wg router? default wireless password?
push reset button at least 10 seconds
Posted on Jul 10, 2009
jepito
  • 216 Answers
SOURCE: how to connect to xbox live through sky sagem
reset the router to default settings first...
Posted on Dec 27, 2009
  • 52 Answers
SOURCE: Router Password
try admin and admin again for password. If that is not it try leaving the password box blank. Good luck Are you sure you did not change the password when you set it up the first time. If you did you have no other option than reset.
Posted on Jan 30, 2008
  • 244 Answers
SOURCE: have wireless signal but no IP
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Posted on Jun 28, 2009
  • 9 Answers
SOURCE: My D-link dir-825 router has been giving me poor signal
Hi Friend,
Firstly,u need to do following settings to u'rs belkin router: Default ip address of D-link dir-825 is 192.168.0.1
,so you can login to router setup page by http://192.168.0.1
1> You need to reduce MTU<Max.Transmission Unit> to 1400
2> Change wireless channel to 9/11
3> Wireless MAC ADDRESS CONTROL should be disabled for u're xbox
4> Reduce beacon interval to 50/75
5> Fragmentation Threshold:2306, RTS Threshold:2307
6> Disable the security/firewall of u're router
7> Do the port forwarding/trigerring;port numbers for xbox are:53,80,88,543,3478-3479,3658,5223,10070-10080
it will be good if u change wireless network name(SSID) as well as upgrade the firmware of u'rs router;so that it will reflect the effect & power down u're x-box while doing the changes in router.
If u need technical help in order to do the above changes in router have a words with belkin technical suppoprt.
Posted on Mar 19, 2010
Tablet says authentication problem even though signal excellent
you may need to go in to your router bios it may have something to do with the setting
Feb 13, 2014 | D-Link DIR-615 Wireless Router
Cant connect to internet
Try entering password again off router. Unplug and replug router then try again. Make sure your WIFI is on too.
Feb 06, 2014 | Dba Archos 5 160 GB Internet Tablet with...
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
I am getting "Authentication Problem" with WiFi on 2 tablets - excellent signal. Accepts the security code and will hold for a minute or so.
I see three points:
1. check if the password of the router is the same you have signed in the wifi-account of your tablets - it's typical that a wrong password is prompted with no error message.
2. check if the wifi-protection of your router has the same type (WPA, WPA2) as your tablets use
3. check if the router accepts new wifi-devices, sometimes there is a checkbox "only known devices can access via wifi"
greetings, bernd-steffen
Oct 12, 2013 | Android Tablet PC
Can't connect Android tablet to Wi-Fi
Android ICS has problems connecting to secured wireless routers, try setting the security to wep if it isn't or if that doesn't work set it to none. This is a known bug in ICS and most vendors will patch it.
Dec 23, 2012 | Computers & Internet
My wifi doesn't work.
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 08, 2012 | Computers & Internet
I have a Belkin wireless router connected to a Virgin modem. Always has worked fine with a Compaq laptop and 2 Dell Inspiron netbooks with excellent signal. Now have tried to connect with an Acer Revo rl...
The router is designed in such a that it is compatible with all the computers. The best way to get rid of this issue is log into the router interface and change the wireless channel to suit your requirement.
1) To begin with.. Open internet explorer on a computer connected to the router and delete everything from the address bar and type http://192.168.2.1 and hit enter. Now you will be in the Belkin Router setup. It will ask for a login password when you click on anything.. Leave the password field blank and click on submit. 2) Towards the left side under wireless click on "Channel and SSID". Now you see wireless channel change it to different channel and click on "OK / Save". Now check the signal strength in your Acer computer. If its still the same try different channel and check.
Hope this helped.
Feb 22, 2011 | Computers & Internet
Wireless Network Connection constantly reading low/vlow/no signal
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
Jan 04, 2010 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
