Question about Frigidaire GLTF2940ES Front Load Washer
I started with E20, pulled the hoses off and the drain was clogged. I "put it back together" and now Im getting E59 code. What did I do wrong?
  • 6,784 Answers
E59 No tacho signal for 3 seconds. This is a motor issue. follow the steps bellow to diagnose this issue.
Remove the belt from the motor and spin the
motor pulley. Does the motor spin free? If the answer is no to the question, you will need to replace the motor. if the motor is free, move on to the next step.
Disconnect the plug from the drive motor and
measure the resistance between pins 4 & 5
in the motor. If the meter reads other than between 105 & 130 Ohms, replace the motor. If the reading is between 105 & 130 Ohms, move to the next step.
Disconnect the plug from the motor and
measure the resistance of the windings (pin
1 to pin 2, pin 1 to pin 3, pin 2 to pin 3). All
readings should be between 4 and 6 Ohms.
If the readings are correct, replace the speed control
board.
If the readings are incorrect, replace the motor.
Posted on May 19, 2009
  • Michael Masters
    Michael Masters May 19, 2009
    Please rate and have a great day:)
I thank you so much for your guidance on repairing my Affinity with the E20 code.I went through the process - It was totally clogged. I put everything back and the washer does not drain still. What do I...
The E20 code is a general pump failure code. This is usually the pump being clogged.
Try using a wet/dry vacuum on the end of the drain hose to see if there is a blockage that you don't see. If you still get the error you will need to replace the drain pump.
Here is the new drain pump to order.
Nov 25, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
What does e20 mean on a zanussi electrolux progress 1200 hydrosystem
The error e20 indicates towards pump.The pump needs to be checked. The pump is blocked or broken.e20 is a not draining error code,check filter at bottom.could be faulty pump or something jammed in the impeller. --------------------------
You have a blockage in the drain hose I would suspect.
Keep putting it on drain till you get the water out or simply lower the drain hose into a wash basin.
Once it's empty, put a couple of towels down, unplug the machine and lay it carefully onto it's left side. Left side viewed from the front. (turn off the water first and disconnect the fill hose if necessary).
You can now take the drain hose off of the pump and take it out of the appliance to check for a blockage.If no blockage, you'll need to take the pump out and check that too.
Check the hose first.Also check for any small cloth getting blocked in the machine inside.
To remove the pump,It's clipped into the base.Look at the underside of the base.Squeeze the clips together and push them into the base a little.You can then slide the pump out of the filter housing.Watch for the O ring as this has to go back on to seal the pump.The pump slides in and out.
You'll only need to unplug the wiring.If hose or pump checked out faulty then it has to be replaced,if filter is clogged clean it.
---------------Thanks.
Mar 01, 2011 | Washing Machines
My frigidaire front laod washer has an E20 error message.
E20 error is known for pump out issue.The first thing I recommend is to take off the front bottom cover(below the door) tilt the washer back some,remove the clamps and hoses from the drain pump.It should be on your right hand side.Check the pump and hose to remove the clogging.This tends to be a common problem with Frigidaire front loaders.Now when you all done with that put it back together and do a test run.
Apr 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Clean clothes
The E20 code indicates a drain problem. Check the drain hose for kinks and obstructions. Next, remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller for broken/missing blades and make sure the impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely the pump is defective. Hopefully it is just a clogged drain line or pump. Hope this helps and best wishes.
Aug 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
May 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code E20. This is not listed on the error code chart. What do I do to fix the problem.
E20 means the drain hose is plugged or kinked or the household drains are plugged. YOur washer will not drain and spin until this is fixed.
turn off the washer/unplug it/remove the drain hose and check for a clog. If it is there, clean it out. If not - check your sinks and toilets for slow running drains. The garbage disposal is a good place to start as well. plug the sink, fill it with hot water, then pull the plug and start the disposal. That will help clean the disposal and also show you if you have a drainage problem there. Plunge the toilets, etc.
Good luck to you!
Aug 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
287 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
