Without remote control
Sometimes i take my dvd to Hotel to watch dvd. But i can do it because remote in the hotel do not have the button to change the sorce fromm tv to hdmi and u can not change the option throug tv also. Is there any other way to change the option.
    Top Expert:
  • Televison & ... Master
  • 34,153 Answers
You will have to take the remote for the DVD with you.
Posted on Dec 27, 2013
SOURCE: I need the codes for a brightstar br100z remote for a symphonic t
Hold the set up button until the red light stays on on the remote. Press power until the TV responds. My sleep timer displayed after 23 presses (hotel room Magnavox TV). Stop pressing remote. The red light will then flash a few times once you stop. Problem fixed.
Posted on Feb 18, 2009
SOURCE: Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
Posted on Jun 23, 2009
SOURCE: Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Posted on Aug 08, 2009
  • 325 Answers
SOURCE: stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
Posted on Sep 17, 2009
SOURCE: I have a 19" Genesis LCD TV and I need the Remote Control Code
I have a 22" genesis LCD and can not get my Direct tv remote to work?
Posted on Nov 14, 2009
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
Apr 21, 2017 | Panasonic Televison & Video
I need the code that will tske my samsung 40" out off hotel mode
hello,
To switch off hotel ode on samsung, enter:
1. On standby press info-menu-mute-power or,
2. press mute-1-8-2
After service mode appear, Choose option block,
Fine Hotel mode, change to off.
If in option block you can't fine it, try open other block.
Good luck.
Apr 16, 2011 | Televison & Video
Hotel
It needs to be re-programmed to use your TV. Here is the manual link. Follow it to program the remote for you TV make.
http://audiovox2.info/docs/rca_acc/man/RCR350_DOC_OM.PDF
Jul 05, 2010 | RCA RCR350 Remote Control
Access menu settings on on Sharp Aqous without remote
look for a set of 2 - 6 buttons around edge, top, sides, of unit, under a flap, you can do all with those keys.
Feb 16, 2010 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Lg hotel tv. t.v. button are locked out, only hotel remote works
Hold down the MENU button on the remote for approx 5 seconds. Then enter 1105 this will access the hidden hotel option on the LG tv so you can change whatever you like..
Cheers LITTLE DISH FITTER
Jun 08, 2009 | Televison & Video
Stuck in hotel mode 32 lg lcd
Hope this Helps
Cheers
Little Dish Fitter
Jan 16, 2009 | Philips RC2573 Remote Control
Hotel TV remote
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
