Question about Miele Dishwashers
Miele g685 red light for water intake flashes
The machine was working when the water supply stopped. the machine stopped, the water intake light started to flash and it didn't went on with the program later. when the machine was opened the water inside wasn't drained. the light still flashes and it seems like the electronics is blocked.
  • 9 Answers
SOURCE: Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Posted on Apr 20, 2008
SOURCE: intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Posted on Sep 04, 2009
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
SOURCE: Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
Posted on Jun 08, 2010
  • 177 Answers
SOURCE: my miele dishwasher shows intake/drain light
hi, firstly check the filter in the waterproof system where the tap is to make sure it is not blocked. turn off the water and remove the connection with the white box attached this is the waterproof system. remove the black seal and you will see the filter. pull it out with a pair of pliers and clean it.
if this is ok check to see if you have a restrictor on the tap or inside the tap and also make sure water is flowing from the tap prior to reconnecting the waterproof system.
run the unit again and when it is time for the machine to call for water you can manually fill it and see if it works using a saucepan or bucket. if this works ok you may have a stuck waterproof system and probably need to replace this.
Hope this helps
Posted on Jun 26, 2010
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
I have miele w500 problem is the soak/pre-wash
hi, the problem you are having with the "soak/prewash" light flashing after the wash has started is a common fault on the meile washing machine. Its a water sensor problem. remove all srews and bolts from front of machine and open the front panel. you will see a red in colour pressure switch at one oclock, there will be a black tube attached to it, remove the tube and replace it with a new one, or reverse the tube in reverse and you will find that the water intake level will be less and the fault of the "soak/prewash" light will no longer flash, problem solved. 0868887054 DAVID ASHBOURNE. MEATH.
Nov 14, 2012 | Miele Novotronic Premier 500 Front Load...
Hey there, i got a miele w4800 front load washer that stopped working all of the sudden. The buzzer is going crazy and the drain and intake fault lights are flashing. Any ideas of how i could fix this...
You have water in the bottom pan of the machine. grab it at the back and tilt it forward. the water will run out and it will start working again, but you will probably need a concertina hose. This is the hose that connects the detergent compartment to the wash drum.
Feb 15, 2011 | Miele W 4800 Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Jul 25, 2010 | Miele W1903A Front Load Washer
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Dishwashers Logo
114 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
