Question about Apple iPod Nano Seventh-Generation
Why won't my ipod 7th gen turn on
I will be listening to music then it will just shut off and won't turn back the battery was full
You probably have a battery issue or a software problem. Either try to reset it or bring it to apple for the battery part of the spectrum.
Posted on Jan 01, 2014
SOURCE: How to turn off speaker when using headphones
Just had the same issue with my GF's nano so i phoned apple and got the following solution:
Flick the button/switch on the top of the nano on and off 6 times leaving the orange bit not showing.
Now hold down the menu button and the middle button for 15 seconds until an apple icon appears. SORTED!
now the speaker turns off when you plug the headphones in plus rest assured it doesn't reset the ipod and remove your songs.
Posted on Mar 08, 2010
  • 42 Answers
SOURCE: No Battery power remains connect ipod to power
Sounds like your battery circuit is not working properly. Since you have opened it before, open it again and check to see that the little plug where you put the battery tab in is pushed down to make a good connection. Sometimes the plug connector is in the up position and needs to be gently put back down to have good contact.
You could have also messed up the battery connector when you disconnected the first battery to change it. Sometimes that happens if too much force is used. I use a pair of tweazers to just gently pull the battery tab out of its plug. I also use the tweazers to gently push it back in without moving the connector up and down.
You could also have a bad battery. Have you tried putting the old battery back in to see if that works.
Hope that helps.
Posted on Dec 19, 2008
  • 5 Answers
SOURCE: ipod shuffle 2nd gen won't shut off with switch
maybe you have both swich to the same side
Posted on Aug 17, 2009
  • 53 Answers
SOURCE: my ipod nano 2nd gen has a white screen
your screen is broken and will need to be replaced.
Posted on Oct 29, 2009
  • 8 Answers
SOURCE: Ipod touch 1st Gen turns off during restore. (Need Help!) Please?
You might want to try holding the top button and the home button until it turns on, then let go of the top button. Keep the home button held down until the "Plug Into iTunes" picture comes up. You should be able to normal restore now. If this doesn't work, just go get it repaired.
Posted on Nov 15, 2009
How do i delete duplicated photos on ipod Nano 7th gen.?
You'd better cleanup your iTunes library firstly. Just click "View > Show Duplicate Items" and then you would just check off the duplicates that you wanted to remove. After removed all the duplicates in your iTunes, sync it to your iPod, then all duplicates in your iPod will be removed automatically.
Source: http://how-to-delete-duplicates-in-itunes.newgenresoft.com/ How to Delete Duplicates in iTunes 12 11 10 9 automatically
Jun 06, 2014 | Apple iPod nano 7th Generation
7th generation iPod nano won't hold a decent charge.
Hi Sarah!
It is actually a common problem with devices that feature rechargeable batteries. The solution is to condition your battery. Once it is showing a 100% charge, disconnect and do not charge it again until the iPod completely shuts off and will not turn back on. Plug it back up to the charger and repeat. This will condition the battery to "know" when it is full and when it is not. Leaving it charging all day conditions the battery into "thinking" that it must stay charging or it is empty.
Hope it helps!
Dec 09, 2013 | Apple iPod classic 7th Generation
Ipod nano 7th gen no sound
I synched to another computer with windows 7 without iTunes on it, it loaded windows drivers (not something you want at all) Next I had no sound, reset it, nothing. Plugged it back into offending computer and went to properties, remove drivers, warning you are about to uninstall this device from your computer. Yes. Sound works again, had to repost.
Jan 12, 2013 | Apple iPod Nano Seventh-Generation
My ipod touch will not turn on, what should i do?
you can try reseting your phone i had to do it with my phone a few weeks ago
Apr 05, 2012 | Apple iPod touch Second Gen (8 GB,...
Couldn't turn off sound
there are many glitches in the ipod touch 2g. there will always be glitches. if this ever happens again, hold the home and power button until it turns off.
Mar 30, 2009 | Apple iPod touch Second Gen (8 GB,...
Error screen and frozen screen
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Jan 08, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apple iPod Nano Seventh-Generation Logo
251 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
