Question about HP Color LaserJet 2600n Printer
Color prints double shadow
Paper looks grey
That will come from second qoulirty torners....
Thanks,
Nadee
Posted on Jan 02, 2014
4 Suggested Answers
printech
  • 159 Answers
SOURCE: printing color shadow
did you used a combat able cartridge ? if yes the ink is the problem if no the problem is firmware
Posted on Sep 04, 2008
SOURCE: Hp color laserjet cp1215 is laying a shadow double
Press Menu button. Then press the <Left> scroll button and <Cancel> button simultaneously. This will take you to the secondory service menu. Press the menu button and select secondary service. Scroll through the menu item and you will see <Clean belt> option. Select it and press select again. This will clean the belt for you. Do it may be two or three times. This will solve your problem.
Posted on Aug 18, 2009
nonontech
  • 4737 Answers
SOURCE: When printing text in color
Clean the Fuser unit and Remove the Wasted Toner from the Drum, that'll definitely fix your problem. To do these, you have to disassemble the Fuser and also the Drum. If you need further help, let me know with more details so that I can give you the instructions on how to do and how to fix it with the easiest possible hints and instructions.
Awaiting..
Good luck.
Posted on Oct 11, 2010
Why is my Epson WF 2530 double shadow printing?
Allen, that's very unusual. I've been using a workforce printer for years, and haven't ever seen anything like that.
What paper are you using, and what paper setting in your computer?
When you rand a nozzle test, were the nozzle lines even, or did some look kind of out of place? (a deflected nozzle will give that gosting effect, and "underhead cleaning" is the answer)
May 01, 2015 | Epson Office Equipment & Supplies
Whatever I print looks "dirty",
If the cartridges are not HP brand, that may be the problem.
Try to figure out exactly what color the "grey" background color is.
If it is truly grey, the black cartridge might be the problem.
You can also try a different type of paper.
Some paper may respond to the printing process differently than others.
If you find that the background is a red, the scanner will have to be removed and cleaned.
These models have a tendency to collect red (magenta) toner on the scanner assembly lenses.
Mar 30, 2011 | HP Color LaserJet 2600n Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Towards right hand side of printout, characters ap...
If you are getting a "shadow" behind the text or image it is probably your fuser that is causing the problem. Anytime you see a double image or the print is smearing the fuser (aka fixing assembly) is to blame. You can troubleshoot the problem to see for sure before calling out a technician. Send a one page test print job to the printer. Open the rear "output" tray so that the print job exits the rear of the printer. Watch the paper as it is pulled into the machine. When you see the leading edge of the print exiting the printer open up the front door of the printer. This will of course cause the machine to jam up but its worth it. Carefully remove the toner cartridge. Look at the print on the page still inside the machine. Do you see the same grey image? If not then the problem is the fuser. If you do see the grey image then the problem is the toner cartridge. Stopping the print job in the middle of the printer like that allows you to see what the image looks like before it goes into the fuser. If the fuser is the problem call a tech. It is about a $100 - 150 repair for the fuser depending on the labor rates where you live.
May 20, 2010 | HP LaserJet 1150 Printer
There is double printing or shadow-like printing with my HP 6313
change cartridge
the print head of our cartridge is damaged
Apr 26, 2010 | HP Officejet 6310 All-In-One InkJet...
Color and black gets shadow on print out
Go to the printer Setup button, hit Ok, then look for Print Quality, acess print quality and go to calibrate colors, run this calibration for 3 times.
Then go to services and run a 2 cleaning modes
You can try printing blank pages selecting "cardstock" as paper type to clean the fuser
Mar 16, 2009 | HP Laserjet CM2320nf All-In-One Color...
PRINTING IS SMEARY AND NOISY
If there is a clicking noise as the printer is printing then most likely the fuser film has torn. The fuser film is part of the fuser unit. This item is best replaced by a technician.
Have you found pieces of film like material around the printer paper exit? It is most likely a dark grey color.
Oct 13, 2008 | HP Color LaserJet 2600n Printer
HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
Seeker5211
Seeker5211
