Question about Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome...
Moen 7300 does not stop leaking (dripping)
Moen m7300 drips continuously when shut off
  • 659 Answers
SOURCE: dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Posted on Mar 16, 2009
  • 659 Answers
SOURCE: Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Posted on Apr 05, 2009
  • 244 Answers
SOURCE: Moen fauset # 1225 Shower new cartridge and it
is it official moen 1225 ? generics can be of poor quality. turn off house water and remove cartridge. Small fingers? Put in valve and feel for debris or turn on whole house again for a few seconds to flush out valve. try another cartridge. Or try this first. take off handle and push in on stem. does drip stop. ? perhaps handle is not on right.
Posted on May 09, 2009
  • 11211 Answers
SOURCE: Water leaks from around the stem when I lift the
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Posted on Nov 04, 2009
Testimonial: "thank you so much."
motor1258
  • 6674 Answers
SOURCE: how do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Posted on Jan 22, 2010
Bathroom showers drips
Good news MOEN has a lifetime warranty shut water off to shower then remove the valve behind the knob home Depot or lowes give you new one free with old part
Mar 15, 2015 | Moen Home
Moen 7700 kitchen facet started dripping...help?
Dismantel the entire faucet and clean. Probably grime or dirth buildup if it has a rotating shutoff
Jan 25, 2015 | Moen Plumbing
Fix a dripping single handel moen faucet
you can go on line with the make
Nov 11, 2013 | Moen Plumbing
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
Water dispenser leaking dispenses ok, but does not always shut off fully resulting in a slow drip. Like a dripping tap might be just a washer?
you have a faulty water valved solenoid. when you actuate the water lever, the solenoid opens, to allow water flow, then closes to stop it. When you continue to get a dripping before or after, its because the solenoid is not closing completely. Only resolution is to replace the water valve.
Mar 26, 2010 | Freezers
Moen shower head drips. Single lever shower only. Installed by home builder about 2001. How do I fix the drip/leak
Probably need to remove and replace the cartridge. Often sediment will tear part of the o-ring or seal on the cartridge and cause this problem...
varies by model, but generally, remove the cap on the knob, unscrew the knob, remove the keyed sleeve, remove the round trim plate & shut off the service stops (verify they are fully closed by pulling out on the valve stem) next remove the retaining clip (needle nose and be gentle) that holds the cartridge in place, then pull the cartridge straight out with vice grips or similar (or get a puller). clean the cartridge, flush out the valve body by slightly opening both service stops, reinstall cartridge and clip, open service stops and see if it still leaks. if it does, take your cartridge to the store (any reasonable HW or plumbing store should have a replacement) and get a new one. then reverse the process to reinstall.
If you send me the model I'll get you more specific instrucitons and pictures...
Oct 10, 2009 | Moen Home
Leaky posi temp shower valve
coming from the uk it sounds that when you mention it leaks at night its a possibility thats when the water pressure increases & the valve starts to drip?
i know its not a solution but it may help you understand why its dripping at night.
Also the seals might be damaged in which case thats why its dripping check them for damage. make sure when you put the new cartridge in that you put some silicone grease around the seals as this helps the insertion & helps protect the seals from damage.
Kindly
Richie
Dec 15, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
41 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
