Question about Samsung RSG307AAWP
RSG307AAWP ice maker not making ice
I've changed the water filter and reset the ice maker , freezer temp at -8. the water despencer works just fine
3 Suggested Answers
  • 91 Answers
SOURCE: Samsung Refrigerator with bottom freezer model #
Check for ice build-up in and around the freezer fan where the blades are, if you can see ice in there (some times it may look like white foam but dont be fooled, it will be ice), the fan will be hitting it, defrost the freezer and check defrost element, (you will have to dismantle freezer section to get to it but reletively simple job) disconect from mains first. Good luck
Posted on Dec 19, 2010
fourtdollarm
  • 11 Answers
SOURCE: samsung refrigerators
if the filter is dirty enough to where it stops the flow of water then yes.a replacement of the filter should fix the problem for you
Posted on Aug 19, 2012
Why is icemaker not working
Good Morning Friend,
I understand the ice maker is not working in your Frigidaire refrigerator, model# FPHG2399PF. Please follow these steps to resolution:
    1)Make sure the ice maker power switch is on. This button is located on the ice maker itself.
    2)Make sure there is not a small cube caught in the ice maker itself. If there is, carefully remove it.
    3)Check your water filter. Water filters should be changed roughly every 6-8 months. Also make sure your water filter is seated correctly. Try taking out the filter and re-installing it. Listen for 2 clicks and make sure it is flush with the water filter housing.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FPHG2399PF Professional 23 Cu....
French door / lower freezer. The icemaker makes ice fine until tray is about full and then slowly drips water until about 1/8 of ice is frozen together with a upside down brown ice cycle fused to them....
The most common reason for this is that the fill valve for the ice maker is sticking slightly.
The brown ice comes from the leaking water sitting there on either the kickout bar or the gears and you are getting some residual rust deposit.
You will need to take the fill valve apart and clean it or possible replace it, I also recommend installing a water filter for the ice maker if you don\'t have one or replace the old one.
Calcium deposits in water are real hard on these small valves.
Oct 10, 2013 | Jenn-Air Freezers
Hoshizaki km - 280 mah ice maker not making enough ice
A few simple things to check is the condenser for dust. Blow it out. If their is a water filter going into the unit change it. Get some ice machine cleaner and follow directions. Do these things before calling anyone out.
Aug 12, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Ge profile refrig - watrer dispenser does not deliver water. Ice maker works fine. What is wrong?
Water solenoid at the rear of the fridge has failed, there is two or three solenoids there, locate the one that does water feed to the door (not ice maker) and do a load test or just replace. Also make sure you dont have a filter safety cut-off, check filter cond and it is located perfectly in housing, check lines inside and outside fridge unit for obstructions. Good luck.
Feb 27, 2011 | Continental Freezer Wide...
Ice maker does not make ice i replaced filter still no ice
check the fill tube for ice blockage.some times water will freeze in the tube and stop the water flow.also if the unit has a reset button on the ice make reset it a few times.and if tat does not change any thing check the fill valve and water supply line.last thing too do is replace the ice maker
Jan 22, 2010 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Ice maker icing up
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
Aug 26, 2009 | Kenmore Freezers
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Can you lower the ice maker temp on that model.
Thanks J
Jan 05, 2008 | Freezers
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Aug 08, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Samsung RSG307AAWP Logo
63 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
