Question about Radio Communications
Sound problem Very low sound even with settings on max
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Check headset with other audio sources, if same results on all sources then headset has faulty wiring , probably grounded, have it check , if possible rewire.
Posted on Dec 28, 2013
My tablet sound is low even when i have my volume settings at the max
This may sound silly, bit do you have your tablet in a sleeve or cover? If so, check that the cover is not covering the speaker outlet(s) on the back of the tablet. If it is, a hole or slot cut into the cover over where the speakers are located should fix the problem.
By the way, a quick test to see if this is the proble is to operate the tablet with the cover removed. If the sound is now OK, it's the cover causing the problem. This happens more often than you might think...
Also, some tablet do have really poor audio systems and both low volume and low quality sound. Hopefully your tablet is not one of them.
Jan 01, 2015 | Tablets & eReaders
Max volume to low
Check the settings of the monitor for audio volume. Also check the individual volume control setting for the applications and system sounds. Or call ViewSonic technical support for assistance.
Jun 15, 2014 | ViewSonic Computers & Internet
The volume on one of my Gigaset 8825 mobile handsets is very low. I have adjusted the handset volume to the max setting but still can barely hear the ringer. Is there another way to adjust the handset...
Hi, you can try to change the profile settings of the phone, because sometimes even if the volume is full but if the profile settings is on low, the sound will still be low.
Thank you for using Fixya.
Jul 15, 2011 | Computers & Internet
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Very low sound acer aspire 5611
I have had that problem quite often. Then I usually make use of the EQ settings in the AUDIO program to BOOST the sound.
Jul 06, 2009 | Acer Aspire 7520-5185 Laptop
Volume is too low, even then it is turn up to the max.
Have you looked at the menu on your cable or satellite box to see if there is a seperate volume control for the box?
Usually it is found under
Settings>>Audio>>STB Volume
Apr 10, 2009 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Radio Communications Logo
79 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
