Question about Whirlpool Washing Machines
My washer is not going through the full cycle. The last time it did this I was informed that it needed to be re-programmed. Where can I get code for re-programming the washer? Model 1CWTW4840
Model 1CWTW4840
jaylex
  • 417 Answers
SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Posted on Feb 05, 2008
  • 1294 Answers
SOURCE: Pause during cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 24, 2008
  • 272 Answers
SOURCE: Indesit WDG1095W combined washer/dryer - program wheel stopped
I'm a bit confused you posted under Bosch but you specify Indesit, which is a UK machine. The really bad news is you need to replace the timer. the really really bad news is you can only buy the timers from Indesit, I can't find them anywhere in the US. The really really really bad news is they want 117.99 british pounds for them! plus shipping and handling. Here is a link to the Indesit site where you can purchase one.
http://www.4indesit.co.uk/cgi-bin/product.pl?PID=111846&query=Indesit%20WDG1095WG&model=WDG1095WG&path=52691
Posted on May 22, 2009
  • 1382 Answers
SOURCE: bosch washer dryer WVT2850GB error code E06
Remove the rectangular fascia at the bottom front of the machine - on my model you only need a coin to turn the two plastic screws. Unclip the black rubber drain pipe, remove the plug from the end and drain the water into a bowl (or several bowls).
Then undo the round plug at the bottom left of the machine (more water will come out) which will give you access to the extractor pump. Check that there are no obstructions in there and that the small propeller in there can turn freely.
If there is no obstruction there then we move onto the next steps.
If you can figure out how to remove the front of the machine then you will find this part easier
First, TURN OFF THE POWER. Then, on the front of the machine, on the bottom left, undo the screws that fasten the extractor pump onto the front of the machine. Then pull the machine out from the wall so that you can get to the back of it. Remove the back of the machine by taking out the ten or so screws.
Looking in from the back: At the bottom-front-right of the machine you will see the extractor pump. It will have two hoses attached to it - a fat one and a slightly thinner one. Reach into the bottom of the machine and remove the power plug from the back of the extractor pump. Then, using a pair of pliers (or something similar) to open the spring clip, remove the thinner of the two hoses (the drain hose) from the pump unit. This can be fiddly - especially if you're doing it from the back of the machine.
Pull the hose out of the machine and check it for obstructions. If there are no obstructions in there then move onto the next step.
Reach back into the machine and, again using the pliers, remove the fatter tube from the pump. Remove the pump from the machine and check it for obstructions in the entry and exit holes, and also make sure that the propeller isn't obstructed. Then shake and squeeze the fatter tube to see if there is an obstruction in there
Best of luck.
Posted on Mar 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washing Machine stops in cycle.
The ECU seems bad.
Look for the service manual inside and do the diagnostic test to see what is wrong.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Whirlpool front loader washer will not do the last drain and rinse cycle. Cleaned the drain pump but still doesn't work. When it gets to the last cycle it just beeps every couple of seconds.
check the pump motor if running when the program is in drainning time,if not!check the power going thru the motor or if theres is, or check the motor winding if its okey!
Oct 03, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Sud error code
I found that mine was having a sud error. I removed the lower front panel and removed the filter. It was full of lint and loose change. I reinstalled the filter and haven't had a problem since. On a side note I found something interesting laying inside. A service tech guide wich stated to do exactly what I had done.
Nov 27, 2012 | Maytag EPIC MFW9700S Front Load Washer
Wont drain with cold water cycle
Need to reset the program and see if there is fault in the water line that does have a low flow and so the program cycle gets a error due to time taken for the rinse cycle.
remove and clean the inlet and the drain pump and hoses.
Jul 04, 2012 | Kenmore Elite Washing Machines
F11- keeps stopping after spin cycle, the last 11-15mins of the cycle it stops and continuously beeps and wont let me open door.
"F11" is defined as a Serial Communications error. This is an indication of a communications problem between the Central Control Unit (CCU), Motor Control Unit (MCU), or the interconnecting wiring between the two. The following link explains:
http://www.fixya.com/support/r3608695-f11_error_code
To rule out the possibility of an erroneous program error, UNPLUG the washer for AT LEAST 30 minutes to reset the CCU. Plug the washer back in and attempt to run a program (DRAIN and SPIN is recommended since the washer has already run through a wash cycle). The washer should allow the tub to fill and run through a drain sequence, before finally doing a final spin. If the error code reappears, you know you have a legitimate problem and will need to troubleshoot.
Remove the top panel of the washer and check all the connections at the CCU, first. Remove the connectors that run between the CCU and MCU and reseat them, one at a time (refer to the tech sheet that comes with the appliance). Sometimes reseating the connector plugs can correct certain problems.
FYI: If you do determine that the CCU is the cause of the problem, some sites may carry a refurbished version that costs less than a new one.
For a full explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to accurately troubleshoot this error code.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices will vary between sites so shop and compare. The first three sites on the list include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. If you have questions, or need additional assistance, please post back and let me know.
Read through the information provided and if you have questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Apr 06, 2011 | Kenmore HE3T Washer
Its flashing f28 and lock i have something in the washer also this is only my secind time using it i unpluged it and its still doin it
If your washer is a Kenmore The F28 error code on this model of washer indicates a communication error between the motor control unit and the computer circuit unit that results in the washer stopping during a cycle.
Read more: How to Unlock a Kenmore Washer HE2 Code F28 ' eHow.com http://www.ehow.com/how_7727221_unlock-washer-he2-code-f28.html#ixzz1GUHtruhM
Mar 13, 2011 | Washing Machines
Hi, Having trouble with my machine. I go to start the cycle and the water will start pumping into the machine and then cut out and then periodically stop and start but never actually full. What is this...
when these machines have a fault thts repetitive eventually it will start beeping and display certain lights in the wash progress & rinse & spin, note these lights down, and get back to me for fault code explaination
Dec 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have an AEG Lavamat L 16850. It has stopped showing an EFO error code for the second time (on the 20 minute cycle both times). The first time I removed the fluff filter which seemed to solve the...
We have this problem for nearly 2 years now. It always occured in a special program ("Kochwäsche/Buntwäsche 60°" what means coloureds/boiled 60°).
The AEG technician didn't find the problem. Since we avoided that program, the problem never occured again.
But now, close before 2-years-warranty-by-law I demanded them again to repair it. I will report.
Oct 25, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
My whirlpool duet front load washer has gotten stuck during the last minute of the wash cycle. This has happened twice. We didn't realize it had happened until we discovered the cycle had continued for...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question((((**))))
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle doesn't cut in
turn program knob to spin and hit start then hit cancel within 5 seconds hold down options and start/pause button this will put you in the self daignostic test
Turn the program knob (1) click clockwise from the
start position. The hot water solenoid will activate
and hot water should enter through the detergent compartment
Turn the program knob (2) clicks from the start
position. The bleach water solenoid will activate and
cold water should enter through the bleach compartment
Turn the program knob (3) clicks from the start
position. The bleach and the wash water solenoids
will activate and cold water should enter through the
softener compartment.
Turn the program knob (4) clicks from the start
position. The door lock solenoid will deactivate and
the loading door can be opened.When the door is
opened, the drum light should turn on.
Turn the program knob (5) clicks from the start
position. The washer will fill and tumble. Once
tumbling has started, the Boost Heater (if so
equipped) will turn on.
Turn the program knob (6) clicks from the start
position. The drain pump & door lock solenoid will
activate and the washer will operate in high spin.
then on the last turn it will give you the other error codes it has that code is giving usually is caused by a different code to clear the codes
• Turn the program knob clockwise 7 clicks from the
Start Position. The control will signal the last error
code.
• Press and hold the Options and Start/Pause
buttons for 3 seconds. The code will be cleared. you really need to clear that code first to do the test but it can be done in the daignostic test skip the rest first go straight to the 7 clicks and clear the code but dont open the door during the test otherwise it will give that code after you get it cleared go to the spin spot on the knob and keep turning clock wise to go through the test but give it at least 3 seconds for each test then it should display a different code and what ever it is email me and i can help you out at that point nick_bradford2003@yahoo.com i have alot of experence with appliances
Jun 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Code lr appears on washer
use normal cycle instead of clean just follow say instructions ..lr is code for remove clothes from tub for clean cycle problem even with no clothes they still show code ..it's a program problem that whirpool is aware of last i heard they were working on solution but instructing cust to just use normal cycle instead
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
125 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
