Question about Nortel Meridian M7208 Corded Phone
How to program lines nortel 7208 - Nortel Meridian M7208 Corded Phone
Can I change the ring tone for just one of the lines on my nortel norstar phone m7324?
If your phone system has 6.1 software or up then yes,the tech or vendor can program it for you. If you know how to program look under Config/Lines for Ring Type.
Oct 17, 2012 | Nortel M7324 Refurbished Norstar System...
Need user/ programming manuals for the 7316 and 7208 nortel phones
The following website will help you with the operation and programming of your 7316:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
This link will allow you to display and save a copy of the 7208 User Card:
http://telecommunications.tamu.edu/userguides/M7208_16.pdf
Finally this link will take you to a site that will have user cards for the phones as well as manuals for the programming of the Norstar Call Manager User Guide:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
These steps should allow you to resolve your issue. If you do have further problems please don't hesitate to let us know. Thank you for the opportunity to assist you in resolving your issue.
Mar 01, 2011 | NorStar T7316E Corded Phone
Can't find "yes" key on norstar 7208 to reset pwd.
It is on of the keys on the side. The 8 keys from top to bottom are: Copy/Yes Backspace/No Change/Remove Add/Default Heading/Retry Show/<-- View --> Back Next/Ok
Excerpt from the 7208 Programming Overlay
Feb 11, 2011 | NorStar T7208 Corded Phone
CAN I TRANSFER CALLS TO ANOTHER NUMBER IF I DON'T HAVE THIS FEATURE HOW DO I GET IT
To transfer a call on a m 7208 while talking to the caller press feature 70 then the number of the extension you want to transfer the call to. You can wait to speak to the co worker to tell them who's being transfered to them or just hang up. Either way when you hang up the call is transfered.
Dec 22, 2010 | Nortel Meridian M7208 Corded Phone
How do i foward to my cell phone from Nortell T 7208 and remove feature
most phones use *72 ### ### #### and *73 to disable it.try *72 first listen for prompts, if no prompts and only a dial tone, then *72 followed by the number to forward to. Hope that helps you
Aug 29, 2010 | Nortel Business Series Terminal T7208 -...
When I plug in my Nortel T 7208, all the lights are flashing. I am guessing it needs to be programmed to work on this phone system? I have other phones just like this on our Business phone system
Nortel sets on startup flash there indicators for up to a minute before there ready to be used. It's like the boot up on a computer.
Jan 30, 2010 | Lands Phones
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
Finding the extension number
press feature *0. you can now look at any button on your phone to see what it is, touching the intercom button will tell you your extension
Aug 18, 2009 | NorStar M7208 Corded Phone
How to add a second lint to Nortel Phone System???
So what, exactly, is your question? Physically, you order a second line in a "hunt" group, and plug or wire it into the system cabinet. By default, a Nortel system has 2 lines already programmed to the sets, but you will probably need to activate the second line appearance in programming.
Carl
May 20, 2009 | Nortel T7316E 2-Line Corded Phone
Meridan 7208 help please
Dear sheryl498,
Your phone is designed for a PBX (Private Branch Exchange) unit like the Compact ICS or the 6x16 TCU that was at the office. It is not compatible with regular POTS lines or standard home lines.
Jul 29, 2008 | Nortel Meridian M7208 Corded Phone
Nortel Meridian M7208 Corded Phone Logo
18 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
