Question about Galaxy Vehicle Parts & Accessories
Galaxy 500 remote won't start or unlock doors
5 Suggested Answers
  • 215 Answers
SOURCE: Wireless remote locks and unlocks
i dont think that your 04 camry has a remote start unless it is an aftermarket installed keyless entry
and remote start. my 03 toyota remote has lock,unlock,trunk onfront of remote and panic button on
the back that is red.
Posted on Jun 16, 2011
  • 18 Answers
SOURCE: remote won't lock or unlock doors
You either need to replace the battery(s) or reset the codes which should be in your owners manual
Posted on Apr 13, 2012
searcher1974
  • 229 Answers
SOURCE: one door remote locks the door but won't unlock , the other remote works fine , I have tried a new battery .
The remote is faulty. Time for a new one.
Posted on Sep 26, 2012
johnjohn2
  • 5763 Answers
SOURCE: 2002 Expedition driver door won't lock/unlock with remote
This sounds like you may have a bad lock actuator, there is an actuator that controls the lock, it may need replacing, you will need to remove the door panel to gain access to it, then with a testlight you will test to make sure the actuator is getting power and a ground and if it tests good for power and ground then replace it and door lock will start working again, this part is about 30.00 dollars. here is a picture of it. good day3_10_2013_6_17_11_pm.jpg
Posted on Mar 10, 2013
2002 rav4 doors won't unlock only lock
Change the battery in the remote key.
Sep 25, 2017 | 2002 Toyota RAV4
Power door lock switch?
Sounds like the drivers door lock switch is bad an as far as the auto start remote the contacts under the button get dirty and won't make contact, open the remote like changing the battery and you can probably get at the contact button, if it's a little carbon button they can be cleaned with a pencil eraser and then paper tower with a bit of rubbing alcohol, if it's an actual switch you can try spraying some contact cleaner into the switch. let it dry before you put the battery back in.
Nov 11, 2012 | Ford F-150 Cars & Trucks
Viper remote won't open door lcks
Does the remote diarm the alarm? Do you hear the " chirp chirp" when you press the unlock button on the remote? If not, then the remote is defective or needs to be reprogrammed to the alarm. If you do hear the " chirp chirp" but, the doors do not unlock, then the issue is with either the wiring from the alarm or the vehicles power locks. Did it work before? Do you have power door locks?
Jul 21, 2012 | Remote Start System
The doors will not lock or unlock from the door but will from the remote?
The title suggest the door won't unlock unless the remote is used but during the summer it was the inverse. If while inside the car the doors will not lock or unlock from the door but will from the remote then you have a faulty switch.If while outside the car the key turns while in the lock but the door won't lock or unlock then the linkage at the end of the lock is faulty. You'll need to remove the door inside plate to check this.
Dec 07, 2011 | 2004 Infiniti FX45
Wireless remote locks and unlocks doors but won't start car. 2004 Toyota Camry
Jun 16, 2011 | Toyota Camry Cars & Trucks
I got the Viper 5101 remote start installed in my 2007 Hyundai Sante Fe at best buy. The remote works for auto start, but will only lock and unlock the doors sometimes. It seems like if I unlock or lock...
I would take it back and tell them they need to fix it. it sounds like a wire for the lock/unlock may of fallen off or there is a problem with the remote stare module. wires tend to fall off if all the used were crimp connectors and didn't solder the wires together.
Jun 01, 2017 | Hyundai Santa Fe Cars & Trucks
Keyless remote will not unlock doors. Door was unlocked with key. Car will not start and the key will not release from ignition switch. Is this the anti-theft and haw do I reset it?
Check the car battery there is a battery in the remote as well but its to new to need to be replaced and so is the battery in the car It sounds most likely like there is a bad connection on one of the battery terminals on the cars battery if the bat is dead in the car the remote won;t work and if the bat is dead in the remote it won;t work but the car will hope this helps
Nov 11, 2010 | 2009 Chevrolet Equinox
Ford galaxy central loking failure problem?
Hi kifixya!
The doors lock automatically at road speed and must be unlocked with the unlock switch before they will open (with the exception of the driver's door). This is how they were designed to work.
To unlock all doors with the remote keyless entry, hit the button twice (like double-clicking a mouse); the first unlocks the driver's door; the second push unlocks the remaining doors.
Hope this answers your request, andgood luck!
-WildBill
Jun 16, 2008 | Ford V6 Pony Cars & Trucks
Vehicle Parts & Accessories Logo
14 people viewed this question
Top Galaxy Vehicle Parts & Accessories Experts
janman
Craig Butler
Craig Butler
Are you a Galaxy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
