Question about Mtd Garden
Have a old mtd coast to coast 32in cut tractor 11hp I HAVE no model number , it is not cutting even Iput new blades and spindels on it but it only has 1 sping on the one side under the driver side that goes from the frame to the cutting deck should i have one on both side?
    Sergeant:
    Champion:
  • 226 Answers
YES! ALSO CHECK TO SEE IF THE DECK IS LINED UP WITH THE SAME NOTCHES ON BOTH SIDES.HOPE THIS HELP'S (RATE THIS PLEASE)
Posted on May 31, 2009
?setup for mower blades mtd 15-36rd is there left and right blade we need a diagram as shown how they are fitted give me a picture the blades ,the blades have wings at one end to allow the lawn go
I do not have pictures but will try to explain. There is no left or right for mower blades. Both the same.
It sounds like mulching blades you have That's ok.
The wings on the ends go in the up location.
If its a 36 inch cut then make sure the blades are 18 inch long each.
Make sure the blades are the same center as the old ones. Or they are made for that mower. If they are upside down you get a very bad cut.
Dec 26, 2016 | Mtd Garden
How can I find a manual for my MTD mow master 11hp ride on mower, model number 1333A
Try mtd website. Usually the real model number is longer than that...check the tag on the mower for another number.
Jul 17, 2016 | Mtd Garden
Bolens belt
if you hit something that hard you my have damaged the spindel housing
May 05, 2013 | Mtd Garden
Middle blade in 3 blade mower for ride on does not seem to cut?
Raise the deck and reach into the bad blade and try and turn it. If it turns easily then try to wiggle the blade up and down. If it moves up and down then the bearings are bad. You will have to remove the shaft and install new bearings. It is best to take it to a shop that can replace them. If you try and beat them off with a hammer you will probably mess up the shaft. I know from experience. You might be able to buy the whole new shaft with bearings already installed pretty cheap. Just find your part number and go to www.jackssmallengines.com and input the part number into the search box. They have reasonable shipping prices. You can also go to your local small engine repair shop they might even have free shipping.
Good luck and let me know if this helps.
thanks
roundo4
Sep 06, 2009 | Mtd Garden
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
What is missing on deck
Yes. All 3 blades should be the same size.
Apr 27, 2009 | Garden
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
Garden Logo
91 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
