Question about Acer Aspire 5100 Notebook
Acer aspire 5100
Will not shut down correctly, it will if i log off & change user then shut down it does.  I have powered off & on hoping it would correct itselp like xp  but to no avail    ty
  • 110 Answers
Re: acer aspire 5100
I recommend just download the trial its a 30 day full functional. I love it, just when you install it, open it up and go to "Clean up and repair" then click Tunup registry cleaner, at the bottom.
Good luck,
Posted on Oct 18, 2007
  • 457 Answers
You have registry problems you a good registry fixer.  Do a google search for one sometimes you can get a shareware one that will fix it.
Posted on Oct 17, 2007
0 characters
3 Points
Forget password . . . cannot open ...
When you boot up to the log in screen type in administrator to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
Dec 06, 2010 | Acer Aspire 5100 Notebook
Acer aspire 5100
Did you try System Restore to restore your computer to a earlier time when it was working properly?
May 28, 2010 | Acer Aspire5100 Notebook
Acer 5100 will not turn on. light comes on and shuts down
Take out the battery and unplug the laptop. Hold down the Power button for 1min. Trust me this happens to me all the time and this is the only way I can fix it
Nov 14, 2009 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 wont start up correctly
Try removing the battery and connecting the AC adapter then see if it boots up.
Reinstall the battery and keep the AC adapter connected and see if it boots up, if so leave it charge the battery for several hours.
If none of these work, get a replacement as there is a more segnificant problem.
I hope this helps.
Good Luck.
Mar 14, 2009 | Acer Aspire 5100-5033 Notebook
How to log off
If you log off you only close your user session under windows, not turn off the computer.
If you suspend you turn off almost everything in the laptop like hardwire, cd or dvdrom and most peripherals but the computer stays on the consuming power.
If you hibernate what windows does is to store all in memory in a temporary file in the hard drive and turn off all the computer so when you turn it on again it will be as you last session with all your programs and documents you left open.
And if you turn off the computer it will close all your programs, close windows and turn off all the hardware.
Jan 19, 2009 | Acer Aspire 5100-3357 Notebook
Acer notebook usb not recognized
Sounds like a hardware issue. I would guess that there is a bad connection between the usb's and the motherboard. If you are comfortable dismanteling the laptop and re-soldering the usb's than give that a try, but I would recomend you give it to a pro.
Here is a link that explains the process.
Jan 17, 2009 | Acer Aspire 5100 Notebook
Xp logs on then logs off immediately on acer 5100
I'd suggest booting into Safe Mode (press F8 after the POST information is finished on bootup) and then you should see an option for Administrator. If you can sign in successfully there, go to Control Panel and create a new account under User Accounts. Boot normally after that and see if you can sign in the new account.
Two questions: 1) is this XP or Vista? and 2) did you recently make any significant changes to the software (namely try to change the Certificate of Authenticity)? If what I suggested works, I'd say boot into Safe Mode again and then run System Restore for Windows. Set the system back to about a week ago and try logging in normally.
Aug 22, 2008 | Acer Aspire 5100-3357 Notebook
Computer screen
Offhand I would suspect video and/or its drivers. Pls try starting in "Safe Mode" and determine if problem persists. If no, then you may need to reload/update your video drivers, if yes, then you have a problem with the video card (hardware). I believe an Acer Aspire 5100 uses ATI Radeon® Xpress 1100 chipset. Am no just sure if it is an add-on card or integrated into the motherboard. Perhaps what you can do is to open the panels underneath the laptop and verify if the different cards including the memory are seated correctly.
Additionally, a post by Mark_Webber, another FixYa expert, addressed a slightly similar concern with another Acer Aspire 5100 here. It might be of additional information. This page might be interesting if not likewise informative.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 16, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
Top Acer PC Laptops Experts
Brian Sullivan
Brian Sullivan
Henk de Ruiter
Henk de Ruiter
Are you an Acer PC Laptop Expert? Answer questions, earn points and help others
