I have an error code F74 on Maytag model # MHN30PDAWW0 comecial front loader.Where do i go to find a list of default codes? Thanks, BD
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
milten1
  • 1304 Answers
SOURCE: what does error code 5ud5 mean on m odel MAH
SUDS
IT MEANS YOUR USING WAY TO MUCH SOAP
for that model you should not be using more than 1 tablespoon
let is set for an hour or so then start a full load of towles with no soap
it should be fine after that
Posted on Oct 06, 2009
  • 530 Answers
SOURCE: WHAT IS ERROR CODE 35 OR ERROR CODE 37? ON MY
does it say f35 and sud?
you need a new pressure switch
sounds like a new washer is it 1-2 years old?
Posted on Jan 10, 2010
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Neptune front loader. What does error code u5 indicate?
Hello. Are you sure of the error code? I checked the service manual and couldn't find that code listed. A jammed or clogged drain pump error is "ND". I need the exact model number to help you most accurately and provide exploded parts diagrams and part numbers. The Neptune series has a lot of service bulletins on components inside. I want to make sure I give you absolutely correct information.
Oct 10, 2015 | Maytag Washing Machines
My Maytag front loader washer gives an F H reading. Purchased in 2009, cannot locate owner's manual.
In the rear of the console inside is the diagnostic test sheets. They should tell you what error code means.
Jan 20, 2013 | Maytag Neptune MAH7500WH Front Load Washer
Whirlpool washing machine wfe 1075 bd error code f13
I had the same problem and looked on other forums.
Many people had said they had success simply giving the door a moderately hard thump! I was skeptical, but prepared to give it a go, so I administered a swift kick to the door.
Lights and action, everything back to normal. Hilarious! This seriously worked - at least give it a go before you bother with anything fiddly or expensive.
Apparently this model has issues with faulty door locking.
Jan 14, 2012 | Whirlpool Washing Machines
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool duet
F74--UI Eeprom failure
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 06, 2008 | Whirlpool AWM9000 Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
