Zanussi zwf1621s washing machine not working.
When the machine was spinning today it made a loud short noise so I switched the machine off. When I went to turn it back on to check if it was working it wouldn't start a programme, the start/pause light continually flashes. Have tried different programmes but nothing will start. all the other lights on machine appear to be working, half load, speed wash etc. I have checked that the drum is still moving freely. and checked the pump which looks ok. What could the problem be?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
IT SOUNDS AS THOUGH THE MOTHER BOARD HAS SHORTED OUT OR YOUR DRUM HAS COME AWAY FROM ITS MOUNT
Posted on Dec 27, 2013
4 Suggested Answers
SOURCE: WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
Posted on Feb 11, 2008
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
Spin - loud noise - switched off - drum wont turn
I'm just hazarding a guess here, but it sounds like the bearings have gone (if you try to turn the drum by hand and it sounds noisy and grinding/crunchy then I think it would be the bearings). I'm certainly no expert though.
Feb 02, 2014 | Zanussi Washing Machines
Sounds like ametal object in drum but there is nothing visible its making a loud banging noise
hello they usually make this noise sometimes a few thing to check make sure the washer feet are adjusted properly if ok .with the power off you could take the top off see if the 2 springs are attach either side of the washer sometimes the snap or come loose also have a look at the suspension legs make sure there tight or not broken hope it helps
regards
shaun
Mar 27, 2011 | Zanussi ZWF12070 Front Load Washer
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
Jan 06, 2010 | Zanussi Washing Machines
Zanussi washer machine zwf1621s does a washeing
3 things you need to check : DRAIN MOTOR PUMP ,
LID SAFETY SWITCH & THE MAIN TIMER , hope it helps , AJ
Dec 27, 2009 | Washing Machines
Loud banging in spin cycle zanussi aqua cycle
if you can get the front plate off you will probably notice that the drum stabilizer roller has either fallen off or is damaged. This part is replaceable and should be no more than 20 bucks.
Apr 27, 2009 | Zanussi F1045W Front Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Loud noise duing spin
not advisable lots of work and costly if your not used to it.Get a new appliance
Nov 13, 2008 | Zanussi FJS1225W Front Load Washer
Noisy spin cycle
Hello your problem is the the drum.. To be more precise its the drum bearing.. theses wear out and can be replaced on the zanussi id suggest that you get an engineer out.. its about £100 to get it done
Dec 15, 2007 | Zanussi F1045W Front Load Washer
Drum noisy when spinning
main wash bearing fail parts for this £48 if you are mechanicaly minded then its a 3hr job if you have all the tools appliance doctor
Jan 28, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
Spin
What kind of noise was it making. Squeaking? Clanking/clunking? Jet engine loud?
Nov 13, 2006 | Zanussi WJS1397W Front Load Washer / Dryer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
