Question about Nikon D50 Digital Camera
Err popping up on top of bar when try to take a picture flash does not come up and also when looking in it also appears inside
    Top Expert:
  • Nikon Master
  • 6,702 Answers
When a Nikon camera says Err, something is wrong with the memory card. Perhaps it is not inserted correct. Or not a card inside at all. Perhaps you can't write to the card or it should be formatted.
When you have a Err, the camera won't do a thing, to avoid the user can think he is shooting pictures and the camera won't save one.
Posted on Dec 27, 2013
Will not tke picture an err message flash at top of screen
Hi anotherie14, the ERR is not a good thing. Try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work then it will need to go to Nikon.
Jun 18, 2010 | Nikon D80 Digital Camera with 18-135mm...
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
I have a Nikon D80 camera that is about 1 year old. I has worked fine until about 6 months ago. Sometimes when I turn it on and press the button to take the picture nothing happens. I have to wait awhile...
Are you getting a Err message? If so The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Mar 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
Function key bar appears on desktop screen
Start - All Programs - Toshiba - Utilities - Settings for Flash Cards
then just place a check mark in the box labeled "DisableToshiba
Flashcards"
Jan 06, 2010 | Computers & Internet
Err 99
err 99 means there is moisture inside of the camera, probably inside the hot shoe
Aug 25, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
I STARTED RECEIVING AND ERR O5 AND MY CAMERA WAS DELAYING ON POWERING UP AND THEN ONE DAY IT JUST NEGLECTED TO POWER UP... PLZ HELP I MISS MY CAMERA!!!!
Err 05 mean that the flash cannot popup. Try to help the flash to pop up when you press the flash button on the front of the camera.
If that works, clean the flash unit from dust and smear or whatever is blocking the flash from popping up.
If your camera is not powering up anymore then there might be a fuse blown inside the camera because of the failing flash.
Apr 18, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
ERR sign
This sound like your auto flash is not popping up allot of the time this will give you a err message and cause a slow reauction to taking pictures causing them eather to be blurry or very dark some times. is your flash working? if it is then it could be you lens try a diffrent lens if you do not have another lens then go to a camera shop allot of times they will let you try out lenses to try to get you to buy one.
Mar 04, 2009 | Nikon D70s Digital Camera
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D50 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
