Question about SP-101 Car Alarm
Crimestopper sp-101 car alarm
I am installing the alarm in a 92 Subaru svx LS, I have it all hooked up but the locks, I have tried Negative trigger and positive trigger. All My books say it is Negative trigger. Even if I put a test light up to the lock or unlock I still dont get power coming out of the alarm it self. When I hook the relays up I can get them to click but I have to power going out to the door locks.
  • Kim Hertig
    Kim Hertig Dec 27, 2013
    Ok so I used my skill am I figured it out. there is a door chime box behind the glove box and under all the other modules. that you need to tap in to. it is a negative trigger you dont need any relays. if you need help I have pics and I can walk you through it. thanks for looking.
  • Vitally Alcher Dec 28, 2013
    why not hook it also to the horn relay
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Crimestopper Master
  • 1,632 Answers
First coneckt the power direct to batery
Posted on Dec 27, 2013
2 way wire diagram
as cars run DC power the polarity doesn't matter in a solenoid unit such as door lock if it has 2 wires ( power wire and earth wire ) Just reverse the wiring and it should work
Apr 12, 2014 | 2012 Subaru Legacy 2.5i Sedan 2.5L 4-cyl....
I cannot get my door lock to work with my new sp-101 car alarm inc my 88 chevy van G20. I hooked up the green wire to the drivers dome switch using reverse polarity as i was told to do, but still does not...
A couple of thing to check. Make sure you are hooking up to the green wire and not a green wire with a small different color in it. 2, Is the door lock power actuator working other than the alarm not controlling it? Is the new alarm system working properly?? The alarm system should have a help line phone number you can call for installation help.
Nov 03, 2013 | Cars & Trucks
I am trying to hook up a crimestopper sp-101 auto alarm in my 88 chevy van, do i need to hook up both purple and green and can i hook it up to the dome wire. This is my first time installing a alarm so...
Is this a new alarm system? Didn't it come with installation directions? The following site lists the system's wire connections; if you want to hook them up differently, do so at your own risk. Good luck.
Oct 11, 2013 | Cars & Trucks
I have a 92 Subaru SVX and I wanted to know if a transmission out of a WRX STI (manual) would bolt up?
It has been done before. There are change-over kits available from multiple sources. Google: Subaru SVX manual transmission conversion (or something like that). There is an outfit called Small Car something. They put Subaru powerplants in VW Vanagons...
Dec 13, 2011 | 1992 Subaru SVX
How do i disable a CRIMESTOPPER SP-101 alarm on my 02 subaru wrx, my remote isnt working
look under the dash and you'll probably see the module and wires. Alarm systems are usually modules (box) that splice into the ignition and lock wires with a big harness under the dash. The harness is a group of wires tied together with usually 2-3 connectors. The harness that the alarm is plugged into is aftermarket and you can remove it. one connector goes to the ignition, one goes to main harness, and one goes to your alarm. Just unsplice the module. Unplug the box and harness it connects into. and make sure you replug in the old connectors to each other. there will probably be some other smaller wires spliced into random wires, just unplug them from the alarm system module. your car should still work fine. and again ****make sure you connect the old connectors from which the alarm was spliced into.****
May 02, 2011 | Car Audio & Video
I have a 92 svx with a starting problem with the starter . i put new batt,pos,neg ,wires and 3 new starters . when i try to start the car the siliniod starts clicking than the car will start sometimes fist...
Shift it into neutral and try. If it starts, the neutral safety switch needs to be adjusted. Some have made a starter bypass mode using a relay feeding the started directly from the battery. Check out Subaru-svx.net
Mar 20, 2011 | 1992 Subaru SVX
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
Have a 92 SVX. The tilt steering wheel will only lock in the low down position, otherwise it just floats! Any ideas?
There are 2 adjusters on the steering column, One on the left side that tilts the wheel up to make it easier to get in and out, and one on the bottom to adjust for comfort.
Dec 15, 2009 | 1992 Subaru SVX
SP-101 Car Alarm Logo
107 people viewed this question
Top Crimestopper Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Crimestopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
