Question about Water Heaters
Bosch propane boiler
We are having trouble getting the boiler to reignite after loss of power and propane tank being empty. Suggestions
  • 31 Answers
Some times you have to bleed the line
Posted on Jan 17, 2014
5 Suggested Answers
  • 4 Answers
SOURCE: i have a ravenheat boiler that i have no idea how to reignite
cange the thermocoupler. you con get one at any Lowes or Home Depot
Posted on Apr 05, 2009
  • 13 Answers
SOURCE: i have a ravenheat boiler that i have no idea hoe to reignite
you need to reset it but if it dont light you prob have rectifaction fault
Posted on Sep 12, 2009
SOURCE: Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
Posted on May 17, 2010
  • 1341 Answers
SOURCE: Worcester bosch 24i combi empties itself after
3 psi is a little over the average, 2.5 is the optimum setting. If it empties itself, it means that the safety valve is working,which prevents any kind of damage to pipes etc...Make sure the valve is open and close at the right time and top up the system slowly rather than in a hurry. If the system requires regular top up then there must be a small leak somewhere, so it is best if you can fix that too. Remember that there are some solutions that are added to the water circulation and if you are constantly topping up with water then you are losing these solutions that prevents rust build up etc...Hope this helps.
Posted on Oct 28, 2010
I've got a Worcester Bosch boiler had a leak In the pipe On the landing so a friend emptied the boiler an I fixed the pipe but I don't know how to refill the boiler
Can you get the manual online? You have the Manufacturer info so you probably have the model number too. I found a manual on Manuals.com for my boiler so they may have yours too which will hopefully have some information on filling boiler although I realize each installation is somewhat different but that's why it's difficult to answer you question. Usually there is a manual pressure valve that regulates the water pressure in the boiler which is usually pretty low...like less than 20 lbs. The manual should tell you the pressure as well. But this pressure valve has a flip handle that comes off the cold water line to the boiler to do just what you want to do...refill it with water. When refilling the boiler (if you find the valve, you may have to purge the air out of the lines which there is a whole other process for. But you shouldn't allow cold water into a hot boiler...it could crack it when the cold water hits the hot cast iron. So make sure the boiler is cool when filling it up.
Now go try to find that manual!
Nov 22, 2015 | Bosch Water Heaters
We have had major blackouts does my bosch highflow 21e need to be reignited or automatic....how long should it be until I get hot water
you have to reignite it yourself turn dial to pilot and press down the light with either the internal igniter or a long match when lit then you turn dial to the ON position .
Apr 25, 2015 | Bosch Water Heaters
The hot water temperature is not constant with the burner shutting off
You can get a sound like that when there is too much sediment in the bottom of the tank. Turn it off drain and flush it until the water runs clean.
Aug 21, 2014 | Water Heaters
Worcester bosch 24i combi empties itself after re-pressurising Whilst re-pressurising boiler my partner (carelessly) went over the max pressure, it hissed & promptly emptied itself- I assume this...
Oct 28, 2010 | Bosch Water Heaters
Empty boiler
Turn main water off to the water heater, it may be a valve on cold side coming in to shut off. Next turn power off to the heater and drain the tank the drain will be located near the bottom of the tank.
You will need a water hose to connect to the drain to run water outside. Open a faucet hot side to allow you to drain the tank.
Upon reinstall connect the tank up and fill tank and open up hot side on one faucet at a time to purge out air from system before turning power back on. Make sure you have water flowing from each faucet's hot side before turning power back on.
Jul 02, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
How is liquid lpg system set up? i have a aqua star mod.125vp that i would like to install in my home, the liquid lpg. is the part im not shure about. thanks d.r.
The lpg either cylinder or gas tank must have a pressure reducing valve which sets the gas pressure to that required by the boiler.
After that valve the piping is the same as for any gas boiler.Where the pipe goes through the wall floor of similar - make sure the pipe has a sheath to protect it from gouges and or wet
The regs - Not sure about the USA but here in UK we have comply. different regs for tank or cylinder
The lpg supplier is a good source of info
Feb 16, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
I have a ravenheat boiler that i have no idea how to reignite
Feb 15, 2009 | Calvin Klein The Field Controls Company...
I have a ravenheat boiler that i have no idea hoe to reignite
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
