Question about Power Color RADEON 9550 R96-LC3 (128 MB) Graphic Card
Powercolor Radeon 9550 R96 256mb Card - Lights on, noone at home!
System - Shuttle SK41G Skt A KM266 with XP-2400+ Processor
8 – 32MB Onboard Graphics
512MB DDR266 PC2100 RAM
120GB 7200rpm Hard Disk Drive
1.44MB Floppy Drive
Problem - Have changed BIOS to AGP 1st and 256mb.  Have unistalled S3 display driver.  Have removed old PCI 56k modem.  Have checked 200w PSU (No problems).  Have readied ATI Catalyst with necessary drivers.  Have put in new AGP Graphics card.  Booted system, fans turn, lights glow, all very positive.  Negatively the mouse has no power through PS2, nor the Keyboard.  Windows XP does not load. Nothing at all on the screen.
 Any ideas? What have I done wrong this time?
 Much appreciated, Jon.
  • 8 more comments
  • Anonymous May 18, 2009
    Hiya, thanks for the help.
    It only happens when the card is put in. I've made sure it is well set in properly.
    Removing the card means it works properly. I have the VGA plugged into the old port and it works fine.
    When it is plugged in the fan starts on the graphics card and the computer begins to load but then just hangs.
    Thanks again.
  • jon55mcc May 18, 2009
    Sorry. guest is jon55mcc.
    I'll have a go with the new BIOS settings.
    I'll let you know.
    Cheers.
    Unfortunately there is no option for 'auto'.
    This is bonkers. The fan on the video card spins, but all else just stops.
    If it is a PSU issue, surely it just wouldn't turn on at all?
    It needs the HDD to start. Have disconnected the CD and floppy Drive with no joy.
    Have done a PSU wattage calculator and came out with a 156w necessity, which is within my 200w limit.
    I really don't want to spend £95 on a new 300w PSU only to find it doesn't work.
    Poo. I'm flommoxed!
    I'm going to take the PSU out of my other computer and test it in the morning. I won't let this beat me!
  • jon55mcc May 19, 2009
    Update - Definitely not a PSU issue as I have the same responses from a brand new 650w unit.
    I have set the graphics in BIOS to check the AGP first, and by disabling the onboard S3 graphics through the device manager I can't see what I'm doing wrong.
    Is there anything else I can do to turn off the onboard motherboard graphics?
    Cheers, Jon.
    Have figured it out I think!
    Finally!
    This card is AGP 8x
    I think my card will only accept AGP 4x
  • Fabio May 11, 2010
    So the system does post (beeps) ?
    Try changing the bios from 256mb to auto as this has to do with the onboard memory.
    Did the problem happen after installing AGP card?
    If you remove it does the system load?
    Make sure everything is well seated and connected.
  • 400 Answers
Depends on the video card ,it might require more power ,200w is fine for onboard but add other components and the system needs more power.
Disconnect the harddrive or CD ROM drive and see if the system will start.
If it starts then you will need more power 300-400w at least but shuttle power supplies can be expensive to get.
Posted on May 18, 2009
AGP cards and AGP slots have two horizontal layers of contacts that are staggered vertically. ATX family computers always have DC power in some places on the mboard, including some of the contacts in the AGP slot, even when the computer is NOT running, as long as the power supply is receiving live AC power.
If you don't REMOVE the AC power to the computer when plugging in or unplugging the AGP card, you will probably DAMAGE the card's circuits or the slots circuits or both, due to the contacts being staggered.
Assuming that he REMOVED the AC power to his case when he plugged in or unplugged the 9550 card at ALL times to prevent DAMAGIING it and/or the AGP slot circuits.....
The most likely cause of jon55mcc's problem was the 200 watt capacity of his particular power supply was not enough to support both the rest of the system's and the 9550 card's power requirements.
It would probably work fine with a PS that has at least a 250 watt capacity, maybe ~ 230 watt.
I have a Radeon 9200 card that works fine with a system that has a 250 watt PS, but it won't work, the system won't boot, with a 200 watt power supply. The 9550 probably requires about the same amount of power or a bit more.
You can usually buy a replacement proprietary (oddball sized) PS on the web for a Shuttle XPC Barebones system from other than Shuttle that will fit in the case that has more capacity. Search using the Shuttle part number or the PS manufacurer's part number that's on the label on the PS.
I've examined the propreitary (oddball sized) PS used in a friend's Shuttle XPC system, I investigated getting a replacement for it that has more capacity on the web, and I've replaced one of a similar size in a HP small form factor system that died with one that had more capacity. They're in a relatively tiny metal enclosure, have a tiny fan, and there's not much room inside the box for air to get in and out of it. They're more likely to malfunction than regular sized PSs with their relatively large fan, and even if the PS was originally capable of supplying the rated wattage capacity, it's more likely than for a reguilar sized power supply that they can no longer actually do that as time goes by.
If you replace the power supply make sure there's as little as possible in the way of it's opeinings.
" Have changed BIOS to AGP 1st and 256mb."
When your mboard has onboard video ( a video adapter built into the mboard) and also has an AGP slot, when you install a card in the AGP slot and if it's recognized properly, the bios automatically DISABLES the onboard video, and any settings in the bios regarding how much ram installed in the mboard is shared with the onboard video are ignored.
The settings in the bios for Primary video or Intialize video first or similar - e.g. PCI, AGP, Onboard - CANNOT disable any of those video modes while the computer is booting BEFORE the operating system loads, and if you have Win 2000 or higher installed, Windows will have basic VGA video when the specific drivers have not been loaded in Windows yet.
However, if you have an AGP card, that setting should be set to AGP, because if that's set to something else Windows will not be able to properly use the enhanced settings and features that the specfic video drivers for the video chipset provide for the AGP card - it will still work, but not as well as it was designed to work.
(In ME and below, you may get no video at all in Windoiws if Primary video or Intialize video first or similar is set to the wriong mode in the bios. )
Ads for video cards often mention only the max AGP mode the video chipset supports, or not all the modes it supports. The video chipset usually supports other AGP modes as well.
All AGP video chipsets that support 8X AGP specs also support 4X AGP specs.
If the mboard's main chipset doesn't support 8X AGP specs but it does support 4X AGP specs, the 9550 should work fine, automatically, in 4X mode
See the info here:
18872 ATI AGP Graphics Cards - AGP Compliance Details
http://support.amd.com/la/kbarticles/Pages/737-18872ATIAGPGraphicsCards-AGPComplianceDetails.aspx
You'll see there that...
Radeon 9550 supports only 4X / 8X AGP modes
Some Radeon video chipsets, e.g. many 9500 and below, etc., support 2X mode as well as 4X or 8X mode.
Some mboard main chipsets that support 4X or 4X / 8X AGP modes ONLY can be DAMAGED by installing a card that has a video chipset that supports 2X / 4X or 2X / 4X / 8X modes, there's often a WARNING in the manual for mboard about that in that case, but that can't apply in this case.
With very few exceptions, if the video chipset supports 2X mode as well as 4X or 8X mode, the contacts for 2X mode are wired up to the video chipset on the card. If the card you're using is an exception, that will be probably be mentioned in the manual for the video card.
Posted on Apr 25, 2012
ATI9550 driver for win 7
go to ati.com driver download make sure u inter agp and the right operating system type x86 or x64
Apr 29, 2014 | ATI PowerColor R96-LD3 RADEON 9550 256MB...
I need a driver installer
Hello rdrhomesite0, I found latest driver for your ATI PowerColor R96-LD3 RADEON 9550 video card fully compatible with Windows Vista, Xp. Click save driver to your computer, install the driver, don't forget to restart the computer. Here is the link.
Copy and paste link into your browser and press enter.
For Windows Vista
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_vista32.aspx?type=2.4.1&product=2.4.1.3.13&lang=English
For Windows XP Professional, Home Edition
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_xp.aspx?type=2.4.1&product=2.4.1.3.13&lang=English
Nov 05, 2010 | ATI PowerColor R96-LD3 RADEON 9550 256MB...
Will My ATI RADEON 9550 Video Card Work With GTA IV/4? the boz says: "ATI RADEON 9550 FUELED BY SAPPHIRE" "256MB DDR MEMORY" "WITH TRIXX OVERCLOCKERS UTILITY" This Is The Same As My Video Card:...
these are the specs you need!!
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Jun 15, 2010 | ATI RADEON 9550 Graphic Card
Can i put a ati radeon 9550 graphics card in a dell dimension 2400
You can put any graphics card in any machine you just need to install the proper driver
Use to be a jumper on the mother that disabled the onboard video but today I think the soft hardware saves use the trouble.
You can run 2 monitors at one time using the 2 video graphics... card and the one on board just set you display properties
Jul 30, 2009 | ATI RADEON 9550 Graphic Card
CONNECT 3D RADEON 9550 256MB display problem
That graphics card i'm afraid is not good for todays games, same thing goes for your pentium 4. A driver update may fix your problem but that card and cpu need changing, probably a new motherboard would be needed also to fit a pci express graphics card along with a core 2 duo processor.
May 25, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Lost cd for radeon 9550
With Windows XP & ATI Radeon 9550 (128MB), the latest driver that will work is this one (newer ones will not, at least not correctly): http://hotfile.com/dl/7470038/955be30/6-5_xp-2k_dd_32464.zip.html
P.S. I can always upload it again, if the file has expired....
Apr 08, 2009 | ASUS A9550GE/TD Radeon 9550 Graphic Card
I want to share memory with my graphic card ati radeon 9550
you cannot share memory with your graphic card, but the hard drive can share memory with your system, You need to buy a new graphic card with more memory.
Jan 09, 2009 | ATI RADEON 9550 Graphic Card
Power Color RADEON 9550 R96-LC3 (128 MB) Graphic Card Logo
602 people viewed this question
Top Power Color Computers & Internet Experts
David Payne
David Payne
Are you a Power Color Computer and Internet Expert? Answer questions, earn points and help others
