Question about Rotel RMB-1095 Power Amplifier
Right speaker jack not working
My rotel amplifier is over ten years old. I have not used it on a over three years. Now the right speaker output is not working. Where can I get this fixed. I live in D.C.
    Brigadier General:
  • 8,546 Answers
Why would it die from being in storage? Oxide or corrosion on contacts, volume potentiometer, Tape Monitor or other switch contacts.
Try manipulating all controls and switches throughout their ranges many times and see what happens.
Check the heaphone jack. If it works so does the right amplifier. While you're at it, insert the headphone jack multiple times to cycle its contacts, too.
Posted on May 18, 2009
HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Jun 14, 2014 | Rotel Audio Players & Recorders
No sound to remote speakers in dining & deck areas.
Incoming from WHAT? Ampifiers accept inputs via RCA connections and send amplified audio to the speakers via the + and - OUTPUT terminals.
I'm guessing your colored wires are from your speakers and that there is a piece of this puzzle we do not see - how the speakers on the deck and in the dining area are wired.
You say, "was working ok previously"... previous to WHAT? Something changed.
You can probably troubleshoot and resolve this yourself.
Set the amp to a medium output level.
If the wires are simply leading to either or both pairs of speakers you could select any two of them and connect them to one side of the amp. Only a pair going to the same speaker(s) will produce sound. Once you identify one pair, the other pair probably goes to the other speakers. Connect them to the other channel output.
The last piece would be to establish correct phasing between the speakers. Bass response will suffer if they're not IN-phase. Play something with substantial bass. Listen closely, then reverse the wires on one side only. Test again. If it IMPROVES you have it right. If it losses bass, put the wires back the way they were.
Apr 27, 2010 | Rotel RMB-1095 Power Amplifier
Checked both speakers..no matter which i connect to right output speaker terminal.get static.speakers r fine. system is ten years old.
Right output transistor is fried, replace . Take old ones (both left and right) to radio shack for new replacements.Replace BOTH
Dec 07, 2009 | Adcom GFA-5300 2-Channel Amplifier
I have rotel amplifiers when i connect my speakers the amplifier stop working
check the ohms on the amp output and the amount of ohms on the back of your speakers they should be the same (or at least the amp should be more) ....your speakers may be overpowering your amp
Jul 01, 2009 | InFocus 1:2 Distribution Amplifier...
Rotel power amp
some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
May 20, 2009 | Rotel RMB-1095 Power Amplifier
No output in Right channel on my Adcom preamp GTP-450
Hi...
Have you tried swapping speakers to see if the trouble moves to the other speaker?
It could be a dirty selector switch .
It could be a broken solder contact on the input or output RCA jacks
Feb 07, 2009 | Adcom GTP-760 Amplifier
Rotel PReamp, Can I directly Connect my powered speakers to the output
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Nakamichi AV-7 Receiver
Help with my power amplifier
This sounds like there is a problem with the final output stage. Is this a new amp? Is it under warranty?
Dan
Oct 08, 2008 | Rotel RMB-1095 Power Amplifier
Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Apr 13, 2008 | Rotel RMB-1095 Power Amplifier
234 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Stuart Slabber
Level 1 Expert
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
