Question about Smeg WDF16BAX Front Load Washer / Dryer
Leak door Door repair
Is repair time and parts extensive for this type of repair? Kenmore Front Load Model# 110.45986401
Confirm that it is not the door seal. The door seal can easily be replaced and the parts are available.
You would expect that any water leaking around the door seal would migrate down to the lowest part of the tub leaving the appearance that the leak is where the two half's of the tub are joined by the retaining clips
Replacing the seal between the two tub half's is a different story as compared to the door seal. The tub seal is definitely do-able, but not for the faint of heart!!
Washer Tub Seal Replacement Frigidaire Front Load Washing Machine Repair...
If the leak is very very small I might wait until a major overall is require such as the tub seal/bearing. If I chose to wait I would monitor the situation.
Inspect the area at the hub of the pulley looking for streaks of rust.. If there is an indication that water is leaking past the basket tub seal than doing an over hall now may included front door seal, tub seal, bearing and basket seal replacement.
Dec 30, 2015 | Washing Machines
Water leak out the bottom of the door when it running door seam lose
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Manufacturer Part Number 4986ER0004G
Jan 27, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Counter saver plus 62702 kenmore
If you repair a door assy. you are required per DHHS rules to perform a leak test on and around the door after such repair.
Oct 07, 2013 | Hotpoint RVM1435 Microwave Oven
Dishwasher Leaks
Find a new repair person
Apr 07, 2017 | LG LDF7932ST Dishwasher
I have GE side-by-side refrigerator, model GE GSS25LGM BWW. The tube from bottom of freezer door to water dispenser is leaking. It probably got damaged during our move when we removed and door and sat it...
I am sorry no repair I know of. As a repair tech we have to change doors often due to the same waterline freezing. there is no way in without damage to door . however you can buy the door from GE for about 300-400 dollars or do without ice & water thru door. Sorry I hope this helps
Aug 18, 2011 | GE GSS25LGM Side by Side Refrigerator
My bosch 2862 is leaking from the bottom - is this repairable ?
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Sep 19, 2010 | Bosch Washing Machines
I have a maytag neptune washer mah5500bww that has been leaking a little under the front end of the washer. I just had the door boot replaced and so I called the repair man back. He had no clue where it...
easly fixed in most cases .you can grip the door with both hands and tweak it so the bottom of the door is flexed inward it is a common problem with the habbit of leaning on the door while removing clothing also its common that the untrained repair guy forgot to connect the little drain found at 6 oclock on the door boot after you have removed the front panel
Aug 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dishwasher door leak
Hi
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
A Fixya rating would be appreciated if you have found this solution Helpful.
Thanks
Rylee
Feb 10, 2009 | Maytag 24 in. MDB6100A Built-in Dishwasher
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Smeg WDF16BAX Front Load Washer / Dryer Logo
21 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
Jorge Rendon
Jorge Rendon
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
